Not possible to found datasheet for TEA1090-Please Help
I NEED PART NUMBER 1C CQY80NG
This is a normal optocoupler. Try to replace it by something like 4N35.
The part CQY80NG however has a footprint of 10 mm wide. The 4N35 has about 7,5 mm width. But this is feasble by bending the legs somewhat outwards.
See also the link to the datasheet. The original can be found at Farnell.
CQY80NG datasheet CQY80NG datasheets CQY80NG datenblatt CQY80NG manual...
Jan 28, 2014 | Philips CDR770 CD Recorder
Cxd9841p datasheet sony
You can find a datasheet by searching for CXD9841P although that probably is a proprietary number
Jul 30, 2013 | Electronics - Others
Wiring diagram for sentrex pa120t
I found this, it might help: http://datasheet.octopart.com/PA120T-Wiremold-datasheet-30218.pdf
http://images1.cableorganizer.com/lutron/maestro-wireless-controls/switch-dimmer_Wiring-Diagrams.pdf
Feb 10, 2013 | Electrical Supplies
SGH2D SHS can relace it by UF 4007?
Hi All,
The SGH2D diode is rated at 200 volts 2 amps so so a replacement must match or exceed these ratings, I used a BY299 at 800 volts 2 amps i know its a bit overkill with the voltage but its working,
Thanks, John Porter.
May 18, 2009 | Samsung DVD-V5500 DVD Player/VCR
Wheelalignment
Check out Chilton.com or Haynes.com for your Model. These are Repair Books for Vehicles and they Really Help with EVERY Repair that you may Need to Do. Please Rate My Response! Thanks!
Feb 01, 2009 | 2001 Lincoln Town Car
I need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
Microsoft Access Program
Sure, Assuming that the field types used offer that option, and most do, but memo may not.
While in the table view mode go to the design mode. Once there look for field length option, and make your change. Be prepared to have existing data truncated to the new max length. You have found out that the datasheet view is the quick and dirty way to update table fields and it uses the properties from the table design.
Jun 21, 2008 | Microsoft Computers & Internet
Warfedale dvd
I don't have a service manual, but IC2 is a 1200P60, datasheet can be found at http://pdf1.alldatasheet.com/datasheet-pdf/view/115078/ONSEMI/NCP1200P60G.html
Aug 01, 2007 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
