Question about Kiddieland Toys
Thomas Bubble Blowing Ride on wont blow bubbles
Wont blow bubbles. brand new Never been used put in solution as per instructions & the small white wheel wont turn & no bubbles come out. the button the instructions say makes it work wont work either
  • 156 Answers
SOURCE: how to operate a used power wheels ninja?
It sounds like your power wheels battery is low. Have you charged it up for more than 18 hours.
I seems like power is getting to the back of the toy, so I think it might be the battery.
I would also ask the people at this website http://www.shopjandl.com/kids---baby-ride-on-toys-power-wheels.html
Posted on Apr 23, 2009
  • 204 Answers
SOURCE: TURN SIGNALS WONT CANCELL CLASHING BROKEN PART SOUND IN STEERING WHEEL
you have to disconect the battery and leave it disconected for around a half and hour and then you can remove the air bag. Do not hook Battery back up untill it is all put back together
Posted on Apr 29, 2009
  • 85 Answers
SOURCE: truck wont start keeps blowing the ecm batt fuse
You have a short (bear wire) somewhere. Trace the wire and find it.
Have a great evening
Posted on May 01, 2009
  • 77 Answers
SOURCE: Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Posted on Aug 12, 2009
SOURCE: I just installed a carb kit on my echo srm 230 gas
on my srm-230, there is a screw under the bulb. Panilling9 is incorrect. There is one under the bulb and four on the outside. If yours is like mine, the four screws on the outside hold down a metal plate that in turn hold the bulb against a plastic plate (not sure what this is called). This metal plate has an extension at the bottom to protect the hoses. If this is put on backwards, the protector will be facing the wrong direction and crack the plastic hose connections when tightened (very easy to do without noticing). This would also be assuming that you put the hoses on the carb before you tightened down the metal plate. If this is the case, then air could be leaking in and you can't create a good suction to draw gas into the carb. Of course there are several other things that could be happening here, but just thought I correct the screw under the bulb issue.
Posted on Apr 20, 2010
Pump bubble wont fill up with gas.
its leaking air.. maybe ahead of the gas line running unto the bubble.. is it leaking any gas at all?
Dec 07, 2015 | Stihl Garden
I lost my instruction manual for thomas the bubble blowing train i need a replacement
Try to contact the Manufacturer website. Or try an online Search (Google or some other search engine site) typing in the Brandname, Model # and keywords like "manual" or ".pdf".
Jul 31, 2014 | Toys
Why wont the gas go in the bubble of my stihl F5 85 weed wacker un less i block the return fuel line ?
Most likely has a leak in the system, I suggest replacing the bulb as well as the lines, replacements are usually fairly cheep.
May 29, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
My suitcase on petz5 wont let me put a bubble blower back its annoying and i want to get rid of it.Please oh please help me!!!!
Okay, get out another bubble blowing box, and then put the first bubble blower in the box with the second one. You can put two in one box and put them away together. Hope this helped!
Sep 28, 2011 | Ubi Soft Catz 5 (Windows) (680901) for PC
The belly is full of bubbles and the batteries are in. i can feel it blowing air, but no bubbles come out
Check to make sure the path the bubbles take out is clear of anything in its way. There are also many reviews on this item that say this item does not work the way its suppose to. If you can not get this item working i would suggest taking it back to get a different bubble machine.
May 29, 2011 | Little Tikes Bubble Bellies - Boubly...
I don't have instructions for this as I bought it used. Does the bubble machine need to be filled completely to get bubbles to come out? I was going to try it before Christmas and when I put in a small...
Try filling the resevoir. Another thing that might cause a problem is dried solution in the tube, so running hot water through might dissolve any residue! Hope this helps.
Dec 23, 2010 | Fun Rise Gazillion Bubbles Cinderella...
Won't start
Gas will have to be in the bubble! You may not have enough fuel, the filter may be plugged, there may be a hole in the fuel line. Check all of them and good luck...Lee
Jun 11, 2010 | Homelite Mighty Lite Lawn Trimmer
Smell gas in front of the stove every now and then
put some bubble blowing solution on suspect areas, if there is a leak it will blow bubbles, no joke...
Mar 25, 2010 | Frigidaire FGF337BC Gas Kitchen Range
Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Aug 16, 2009 | Home
Toys Logo
Top Kiddieland Toys Experts
ray gallant
Handyman
David Payne
David Payne
Are you a Kiddieland Toy Expert? Answer questions, earn points and help others
