Samsung galaxy gear error 4002 - Office Equipment & Supplies
What is the most likely reason a Samsung gear 2 neo touchscreen would be unresponsive to turn on and off
If your Samsung Gear 2 Neo refuses to turn on:
1. the first thing I would suspect is a dead battery
2. If it does not showing charging when connected to the charging cradle:
A. it could be either a bad charging cable, wall adapter, cradle, bad battery, or the internal charging connectors.. Do a process of elimination only with OEM Samsung cables and charging adapters.
Note: the Samsung Smartwatch charging cradle is not normally sold in stores, so if you lost it contact Samsung support to get another one [1+(844) 454-5925], or download the Samsung+ app from the Google Play App Store to access Samsung Support contact information
B. If the Smartwatch has been on the shelf for a long time (either in store or not used after a long time) the battery will deplete itself so low that it needs to be trickle charged for 10 hrs or less depending on how dead the battery is.. Rather than being put on it's regular charge adapter for a few. Try inserting the charging cable into a computer USB port instead of into the wall charger adapter (see attached video)
3. If the Smartwatch is on, but won't turn off:
A. it may be a software issue.. Like an app you installed is clashing with another, or maybe an update got corrupted by a bad bandwidth connection.. If this is the case reset the watch and start over.
B. It's possible you have too many things going on and all the RAM memory (the brain) not storage space, has been used up.. Which is a temporary crash, just like when you over load your brain with too much stuff at one time..
Samsung Galaxy Gear not working
Dec 20, 2015 | Samsung Cell Phones
How do i get my text and email on my smartwatch (samsung galaxy gear sm-v700)
From your samsung phone, select the apps that will be shared with your smartwatch
Dec 31, 2014 | Samsung SM-V700 Galaxy Gear Watch
How long will the battery on a samsung galaxy gear smartwatch last?
According to Samsung's site, the battery on the galaxy gear smart watch should last up to 25 hrs.
Mar 06, 2014 | Samsung Galaxy Gear Smartwatch- Retail...
What size is the display on the samsung galaxy gear smart watch?
The display on the samsung galaxy gear smart watch is 1.63 inches or 41.4 milimeters.
HOW TO FIX CAMERA FAILED ERROR MESSAGE.HANDLER.HANDLE MESSAGE(-1)
ERROR HANDLER.HANDLE MESSAGE(-1)...CAMERA GALAXY YOUNG......!
Sep 12, 2012 | Samsung Galaxy Y
Where do i get replacement gears for this schredder?? dertroyit 4002 thanks
I have a Destroyit 4002 cross cut paper shredder. I have ordered parts twice from shredderparts.com
Both times they were friendly and sent me the correct parts.
Jun 12, 2010 | Destroyit 4002 SMC Shredder
112 people viewed this question
k24674
