Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Windows can not configure this connectio
I have a dell with windows xp. I have installed the software and driver and am unable to connect. "windows can not configure this wireless connection." Now what?
    Novelist:
  • 118 Answers
This often occurs if you install the controlling software that came with the device. If you remove the controlling software, Windows should then be able to configure the wireless device.
Click start, then Settings, then Control panel (you may be able to skip the 'settings' step, depending on your configuration).
Once inside the control panel, find the Add / Remove Programs option and open it.
When the list of programs shows on your screen, scroll down to find anything that starts with Linksys; highlight it, then remove the software.
Restart your computer if asked. Upon restart (assuming the device is connected) if the computer tells you it found new hardware, allow it to install automatically all the way through. Do NOT reinstall the software from the disk that came with the device.
Once this is complete, Windows should configure your wireless for you.
Good luck.
Posted on May 17, 2009
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Hi , i m using dell inspiron N5030, but my laptop was not supporting windows xp, then i install here windows xp+darkedition v7 from then i m tring to install wifi driver but since dell wont provide...
hey You just download patch , which will make your windows 7 driver compatible to windows xp and then before installing it go to wifi software property and then make it compatible to windows xp
Aug 21, 2011 | Computers & Internet
Error in scanner. Turn off scanner and follow instructions in manual.Scanner driver will be closed. (code:201) Unable to open TWATN source Please check connection Then re-start Toolbox.
This error can be caused by many different issues. Try the following resolutions in order until your issue is fixed-
1. You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
2. unistall and re-install drivers-
1. Place the CanoScan Setup CD-ROM into the CD-ROM drive.
2. When the CanoScan Setup Utility menu appears, click the option to 'Uninstall the Software' and then follow the prompts.
3. Disable Third-party Software
Software applications that are active during installation can cause errors, installation difficulties and even abort the installation.*1 Close all running applications, including anti-virus programs, before installing Canon Software. You can also prevent these applications from starting through 'System Configuration Utility' (also referred to as 'msconfig') in Windows 98/Me, Windows XP and Windows Vista.
If your computer is part of an office network: Network permissions, security software, etc. may be interfering with proper communication. Please contact your System or Network Administrator before attempting to disable software on your system.
a. See your applications' documentation for instructions on how to close it.
b. If you are unable to locate the documentation or the application appears to be running after it is closed, disable the startup items in the Windows 'System Configuration Utility'.
c. If disabling startup items in 'msconfig' does not correct the issue, disable non-Microsoft related services in 'Services' tab of 'System Configuration Utility' window.
d. Attempt to install the Canon software (drivers). If the drivers were already installed, uninstall them (keep the third-party software disabled) and then reinstall the drivers.
e. After installation is complete, set 'msconfig' back to 'Normal Startup'.
//javaftper
Jul 31, 2010 | Canon CanoScan 3000ex Flatbed Scanner
Windows xp identifies Belkin f5d5010 Network card as a generic ethernet controller and is unable to find a driver to install properly this adapter
If you find that you can not connect to a wireless base station (such as Apple's Airport) because of issues with the configuration software provided by your wireless adapter's manufacturer. You may wish to uninstall that software (but keep the drivers) and use XP's native support for wireless networking.
In order to do this you may need to turn on XP's wireless zero configuration.
Start -> Run
Type in services.msc
zwc001.gif Click the OK button, which will bring up the following dialogue.
zwc002.gif You may want to maximise the screen. Scroll down to Wireless Zero Configuration and select it.
zwc003.gif You now have the option to Start the service.
You also need to change the Startup Type from Manual to Automatic
Action -> Properties
zwc004.gif Click OK.
You can now use XP to manage your wireless connection.
May 12, 2010 | Belkin (F5D5010) (F5D5010AU) Network...
How to connect Logitech mouse to Windows Vista
go to the logitech website. Logitech.com support. give your model #. Download the complete software pertaining to your model and plug into usb the software will recognize the mouse.
Dec 25, 2009 | Logitech 9311570403 Mouse
Dell Dimension 4700 - Driver Reset
1st you need to download or install all the drivers for your Dell computer. Try to use the drivers/utilities disks first. Once you can get online, go to Dell.com and look up your model 4700 and download all the missing drivers. Your Linksys Router is not a modem. The Linksys has the modem connected to it for wireless connections.
Jul 04, 2009 | Dell Dimension 4700 PC Desktop
Need to setup windows xp faxing
Since you donot have the windows xp cd , you would not be able to enable the fax feature in windows xp home edition.
Alternatively you can download a fax program from the interent and configure the same to send faxes.
One such porgram is called snappy fax, can be downloaded from the link below
http://www.snappysoftware.com/
Thanks
Proton
Jan 31, 2009 | Microsoft Windows XP Home Edition
I want XP drivers
Here is the link to XP drivers for your system. If you had the Dell Resorce disc it should show you which devices you have on your system. If you can get online you may also be able to use the Dell configuration scan utility.
Dec 19, 2008 | Dell Inspiron 1525 Notebook
Windows Xp
In addition to installing the operating system (Windows XP) you will need to install the drivers for the system.  If you system is a Dell Dimension 1100 you can get the drivers from this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_1100&os=WW1&osl=en&catid=&impid=
Driver installation order is:
Desktop system software (R121089.exe) Intel Chipset Utility (R96614.exe) Intel Video Driver (R104515.exe) Audio Driver (R105155.exe) Network Driver (R105786.exe) Modem Driver (R133743.exe or R73044.exe)
Once you have all the drivers installed, then you can install your applications and configure your internet connection.
Sep 07, 2008 | Dell Dimension 1100 PC Desktop
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
250 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
