Question about Conair Health & Beauty
Error message on read out - Conair Health & Beauty
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
Error message reads: Pace error #1
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed.
These errors messages almost always indicate an upper console problem when they are consistently displayed. Failures causing these error messages to be displayed are rare.
If the error message is consistently displayed when the unit is powered up, the upper console should be replaced.
May 23, 2010 | Precor 9.21 Treadmill
Our wii send an error message saying it can't read disc
i had the same problem with my wii. I called nintendo and then had to ship it back to get repaired.
Feb 11, 2010 | Nintendo Wii Console
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Printer not printing. Error message reads see your documentation may need service
Counter reach its preconfigured limit it is just, you have to reset the counter back to zero count. This feature could be attributed not to overflow the waste bin.
In your web browser search bar, key in " epson reset software" the uppermost link is the one. Read the tutorial before doing so.
Hope you get it easily.
May 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
If that's the only error message that you are receiving, I would recommend removing and re-installing the printer software.
May 26, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Error message HO2 shows on vhs display
the player begins to read dvd. display will read 00---READ and it repeats this process a few times and the error then is displayed next.
Jul 10, 2008 | Panasonic Televison & Video
AVIC-N1 wont read navigation disc
If your error message is reading "insert appropriate disk" or "inappropriate disk inserted" than I have the solution. Can you just let me know exactly what the message is?
Jun 05, 2008 | Pioneer AVIC-N1 Car DVD Player
Health & Beauty Logo
23 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
