Question about Harman Kardon SoundSticks II Computer Speakers
Need to replace th 5 pin DIN plug on harmon kardon sounds stick 2- dog chewed thru it and the plug is gone!
  • Fung Huaba
    Fung Huaba Jan 31, 2014
    Hello Bill! Repair should be fairly easy even without the original part. You can solder a new connector, or you could attach the wires directly by soldering or using clip-on connectors. The cable running back into the base has 7 cores. 5 for the 5 pin connector and two for the other speaker. If the original part is somehow still intact, you could just cut out the damaged cable and solder them back on according to the color codes. If the part is gone, you could either cut the 5pin and the cinch connector on the two cables and solder them together or better still, you could get a cinch female adapter and a 5 pin female adapter. Solder them onto the cable that goes into the base where it is still intact. If thats not possible you could replace the cable that goes into the base altogether. The base is held together by 4 screws. You access them by removing the rubber on the four feet, then pull the feet out vertically. Theyre just stuck into the base, no glue, like pins on a guitar. With the feet taken out you can unscrew the screws and open the base. From then it should be smooth sailing. Get a cable that has at least 7 cores and attach it to the mainboard via the 7 pin connector. On the other side of the cable solder a female cinch and a female 5pin connector onto it. theres a video on youtube which shows how to access the mainboard, just search for "Soundsticks II Speakers by Harman Kardon - Disable the Blue LED!"
    New Friend:
  • 11 Answers
If the mentioned cable is the one that is connected to the motherboard of the sub woofer and has two connectors for the speakers on the other side - please contact the Harman/Kardon support of your country, as they may be able to replace this part (actually this is a very rare part) it also may occur that the company will not be able to replace the part with a genuine one, but with a modified one. You can also try to contact some companies that would be able to replace this cable with a custom-made one.
Posted on Jan 16, 2014
  • Andras Arsziri
    Andras Arsziri Jan 16, 2014
2 Suggested Answers
  • 26 Answers
SOURCE: need a replacement power cord for harmon kardon sound sticks II
Hi
please look at your dameged power adabtor suplay it gives you all specification ,like, voltage, amp nad so on, and go to electornice retailers like radio shack ,and............ you can find replacment for it .
make sure have your old one with you , or manual book that came with your spekers.
please let us know if need more assistanse.
Thanks:Marco
Posted on Dec 13, 2008
What are the benefits of chew bully sticks for a dog?
hi there.
Bully sticks aren't just a safe treat for dogs, but offer a variety of health benefits, and give your dog something to chew. Bully sticks are easily digestible, unlike some other chews or treats. The beef hide in rawhide, for example, can be difficult to digest for some dogs. ... Bully sticks are good for that, too!7 Nov 2016
Why Bully Sticks Are a Great Treat for Dogs - American Kennel Club
www.akc.org/content/health/articles/why-bully-sticks-are-a-great-treat-for-dogs/
Why are bully sticks good for dogs?Bully Sticks are completely safe and a healthy alternative to other dog chews out there. Unlike manufactured dog chews, our bully sticks are single ingredient and fully digestible. Rawhide for dogs is still the number one selling dog chew in the US, and we hope to change this because of its poor safety record.Are Bully Sticks For Dogs Safe? - Best Bully Stickshttps://www.bestbullysticks.com/arebullysticksfordogssafeSearch for: Why are bully sticks good for dogs?
Nov 30, 2017 | Dogs
Harman kardon soundsticks ii Hi my dog chewed and ate the DC power plug power, luckerly for the dog it was not the AC end. Now I have had my dogs teeth removed I want to fix the sound system. I can find...
https://www.shutterstock.com/image-photo/muzzle-17780320?src=W0JhB6uuAnfBtLF2bzYYqg-1-42
There should be an international standard number with the plug.
example IEC 60906-3:1994
Search on your plugs number and it will tell you all about the plug that you have.
Usually
https://en.wikipedia.org/wiki/Coaxial_power_connector
The outside on the plug is negative and the inside of the plug is positive on most DC plugs .
With a continuity device like a multimeter you could work out which pin connects to the outside of the plug sleeve that inserts into the device. Being negative .
Jul 14, 2017 | Harman Kardon SoundSticks II Computer...
I have a set of Harmon Kardan Soundsticks II needing a simple but confounding repair. One of the small pins (#5 I would say as you go over and around the arc of pins) of the satellite speaker connectors...
MiniDIN-4 Connector Pinout. Looking at the male connector from the rear (solder side) Pin 1 = White Pin 2 = Bare Wire Pin 3 = Light Grey Pin 4 = Dark Grey Outer case Ground = Clear
Jan 02, 2011 | Harman Kardon SoundSticks II Computer...
Need a replacement power cord for harmon kardon sound sticks II
its not that expensive for a power cord. they are running on 12v so you go and buy a 12v power supply with a jack that fits the speakers or you can just find a power supply at home if you have one that is 12v
Jan 05, 2009 | Audio Players & Recorders
Hi
Thanks:Marco
Dec 13, 2008 | Harman Kardon HK206 Computer Speakers
Harman Kardon Sound Sticks Sub Problem
Oh well, buy new ones. What are harmon kardon sticks anyway?
Mar 09, 2008 | Harman Kardon Harmon Kardon SoundStick II...
Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
Jan 23, 2008 | Harman Kardon SoundSticks II Computer...
Cat at my speaker cords
Most cat problems can be taken care of with a swift kick or a big dog. Suggest you implement this fix before attempting to fix the other problem or you may get a repeat.
Nov 10, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Harmon &kardon sound sticks
you tried it on 3 other computers and ther is no sound at all that mean ther is problem in your set try with connceting thru other audio cable and see . bye
Jun 20, 2007 | Harman Kardon SoundSticks Computer...
Harman Kardon SoundSticks II Computer Speakers Logo
366 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
