Question about Fisher Washing Machines
Fisher amp paykel mw511
Reset the pre-set rinse temperature
JULIANFIX
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
  • 14 Answers
SOURCE: fisher and paykel mw511
temp sensor is bad or dirty with hard water deposits
Posted on Feb 22, 2009
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
HansPP
  • 2510 Answers
SOURCE: fisher and paykel mw511 washes
If it smells during the spin cycle the belt could be slipping and burning in the pulley. You may need to replace the belt.
Posted on Feb 08, 2011
  • 6277 Answers
SOURCE: Fisher and Paykel Pride MW511 does not spin. Three
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 19, 2011
Fisher paykel mw511
take it apart-something has let go in the tub suspension department-springs or bearing-tear it down and it will become apparent-cheers Denny
Oct 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel MW511 error code lights 1 and 7 lighting up and beeping
Error code 130 is rotor position sensor faulty or wiring to it.
sensors sell for $25 to $50 on Ebay.
Jan 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size.
The cold water temperature LED identifies 5kg.
The low water level LED identifies 6kg.
The hold spin speed LED identifies 7kg.
If the product has not been setup before all 3 LEDs will be on.
To set the size for 5kg push the wash temp up button then
the power button.
To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button.
This locks the size
into memory. To check the size is set, start a cycle.
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Oct 12, 2011 | Fisher and Paykel IWL12 Top Load Washer
Washing Machine F&P MW511. Washed, then rinsed using the fabric softener, partially spun then stopped. Will not turn on at all now (no power)
Hmmmmm - I think you may actually have a faulty controller module - without a working module it generally means no power on etc for Smartdrive washers..
Jun 26, 2011 | Fisher and Paykel Fisher & Paykel Washer
Need replacement motherboard for Model MW511 fisher & Paykel washing machine
Hi just read your posting.Have you try ed Fisher and Paykel local distributor ?What country are you in?If you are in Australia I can help you with phone numbers.Please reply with additional information and I am sure I can help you out.Looking forward to your reply.
May 20, 2011 | Washing Machines
U1 code 920 model filter is clean no hoses bent or kinked ? can it be fixed ? hans
The U1 code means:-
Dishwasher attempted to fill to correct level but failed. = Water tap not turned on. Turn the water tap on.
Too much foam. Rinse aid setting too high or has been spilled. = Turn the rinse aid dial to a
lower setting or wipe the spill. Incorrect detergent. Ensure that you use a detergent that is intended for a domestic automatic dishwasher. Egg yolk. Place an extra tablespoon of detergent in the dishwasher door for pre-rinsing.
Too much detergent. Use the recommended quantity of detergent
Wash pump faulty. Call your Fisher & Paykel Dealer or Authorised Service Centre.
Dishwasher not draining. = Drain hose bent or kinked. Straighten drain hose so water can flow through. Strainer blocked. Empty out the strainer and ensure the filter plate is clear of food
particles..
Feb 19, 2011 | Fisher and Paykel Dishwashers
My MW511 model is not spinning , slow motion wash cycles, noisy
Hi blow down the hose that the waste water comes out of, it may be blocked
Nov 29, 2009 | Fisher and Paykel (IWL12)
Fisher & paykel (mw511)
May 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
