Question about Exercise & Fitness
Spirit fitness pro expander 300
Pulleys and cabels
Where do i get a motorola su21 spirit pro manual?
http://www.motorola.com/mdirect/manuals/Spirit_%20M_Series_E.pdf
Mar 28, 2014 | Motorola Spirit HP 2-Way Radio
How do I replace the pull start?
Remove the four screws securing the starter houseing, with the starter removed, pull the cord out, tuck the cord into the cut a way in the side of the pulley and allow the cord to wind in slowley to let the tention off the spring, make sure all the tention has gone, now remove the centre screw, take away the pulley centre and the round spring from behind, note the hole in the pulley and the centre hub for the spring location, now carefully remove the pulley, be aware there is a large spring behind, remove the knot in the end and remove the starter handle, fit the cord back into the new pulley, refit the pulley into the cover making sure to locate into the spring behind, thread the cord back through the cover and reconnect the handle, knot the cord, re fit the round spring back into the locating hole in the pulley, re fit the pulley hub making sure the spring fits into the hole in the hub, re fit the securing screw, now put the cord back into the cut a way in the side of the pulley, wind up the spring, allow it to pull the cord back into the starter, only wind it enough to pull the cord fully back into the cover, re fit the starter.
May 01, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
I need the diagram for the serpinetine belt on a 1991 dodge spirit 3.0
The path of pulleys around which the belt goes (beginning with the crankshaft pulley, and moving clockwise around the array of pulleys) is in this order:
tensioner pulley (belt goes around the pulley counter-clockwise)
power steering pulley (belt goes...clockwise)
alternator (belt...clockwise)
idler pulley (belt going under the pulley)
and back to the crank pulley (belt...clockwise).
Feb 28, 2010 | 1993 Dodge Spirit
What is the step by step procedure for fitting a newfan belt for a Land Rover Discovery 300 Tdi
remove top of fan cowling 2 clips draw a diagram of belt route put spanner on tensioner pulley bolt turn clockwise remove belt with assistant helping keep tensioner pulled back fit new belt over pulleys release tensioner onto belt refit cover
Jan 02, 2010 | 1995 Land Rover Discovery
I need to know how to get the idler pulley off a 97 bonneville to
Its probably a 1/2 or 9/16. Could be any size depending on what GM had in the parts bin at the time. I would buy basic set of wrenches and shold cover most repair duties
Nov 03, 2009 | Pro-Fit Pro.Fit Pt 51 97 Pontiac Grand...
Can't get drive pulley off engine shaft? pullers not working, just deforming the pulley
several things did u check thoroughly for any set screws if no then heat pulley with propane torch (no shaft) when it is good and hot try pulling it then. when u heat metal expands and hole get a little bigger and u can get off , clean with wire brush and heat if needed to reinstall pulley, though if bent very much u need to straighten or replace
Jul 09, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
My power windows on my 300te don't work, i bought it like this and also the fuse for my stereo just sizzles and blows up--i also need a diagram as to where the relays are supposed to go in order, i think...
i think i now whats wrong whit your stereo it sounds like one off the speaker cabeles or the power or grnd cabel is tuching metal some where in the car. check all the cabel on the stereo and se what you find
Jun 07, 2009 | 1992 Mercedes-Benz Mercedes Benz 300 Class
Need to set the time on a Pro Spirit watch
http://www.nsftools.com/misc/TargetDigitalWatchInstructions.jpg
Apr 13, 2008 | Watches
Exercise & Fitness Logo
102 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
