Question about Sharp Televison & Video
Power supply bad on Sharp Aquos LC - bad board - schematic to ID?
I have a 30'' SHARP Aquos LC30HV2U that has a bad power supply. Nothing happens when I turn on the LCD - though it is getting power confirmed by green light going on but nothing on LCD. Visual inspection of boards look fine. How do I find out schematic to find out which board is bad?
Kathy
    President:
  • Sharp Master
  • 1,779 Answers
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
  • 3 Answers
Take a close look at capacitors on the DC power (where the line cord plugs in) - if any of them are bulging or have a white substance on them instead of shhiny metal - then the capacitors are bad. I recently replaced all the capacitors on the DC boards on a coupld 22" LCD monitors and for about $15 each (including shpping) go them both working again. I found kits of capacitors specific to my monitors - could also go to the local electronics component store or other oinline sources to get the individual capacitors for a couple dollars each.
http://circuitsector.blogspot.com/2010/05/how-to-identify-failed-capacitor-on.html
Posted on Oct 27, 2010
2 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: have a 30" SHARP Aquos LC30HV2U that has a bad power supply. Nothing happens when I turn on the LCD - though it is getting power confirmed by green light going on but nothing on LCD. Visual inspection
You did try the CLEAR button on front of the box?
One possible idea is the cables going the box to the TV. ( might be bad )
If your sure about the problem, you can get your Service Manual here:
http://www.nodevice.com/manual/newmans/upsharp/LC30HV2UPDF/get53718.html
This with have all the schematic, diagrams, part number, and test points you need.
My sharp aquos 30 inch tv will not come on. what could be the problem
Hello; I have an similar LC30HV2U for sale in my TV repair shop for $350. This is a 2 piece unit. The AV box and the monitor. I am also a Sharp authorized servicer. In the monitor there are 2 inverter boards on the right side that have an 80 % chance of causing this problem. This set counts "lamp errors" due to one or more inverters not working on startup. Once the set accumulates 5 lamp errors, It will not allow the set to come on. The first thing Sharp tells us is to replace both inverter boards. About $90 each. If those don't fix it the cost will go much higher due to a bad power supply board or bad LCD Panel. Hope this helps, John
Jan 02, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I have an LC30HV2U. When you press the power button, the green light comes on then goes to blinking red. Obviously, no picture. Can you help or make a suggestion
How old is this tv and what are measure you taken to fix tv problem?
Let me know so I might help you to fix its problem.
Thanks.
Sep 08, 2010 | Sharp Aquos LC-30HV2U 30 in. LCD...
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have a 30" SHARP Aquos LC30HV2U that has a bad power supply. Nothing happens when I turn on the LCD - though it is getting power confirmed by green light going on but nothing on LCD. Visual inspection
May 17, 2009 | Sharp Televison & Video
Sharp Aquos LC-42D62U Completely Without Power
If you have no power at all , the then problem concern the power cord or the power supply board.
You need to test the power cable first, and eventually test and replace the power board, the job can be done by any local technician.
Here the replacement power board.
Here all parts for your set: LC-42D62U.
Mar 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Jun 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
replace the supply board
or repair it *** there's problem with supply
Jun 13, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Televison & Video Logo
2,252 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
