Question about Stack-On 6-Drawer Steel Chest and Cabinet Combo
Locked drawer won't open - Stack-On 6-Drawer Steel Chest and Cabinet Combo
Dd603 bottom drawer locked shut, no displays with power on. How do I get the drawer open?
The thermal fuse that cuts of power to the drawer has been tripped. This means you will need to replace the heater assembly at the base of the drawer. It is not cheap - could set you back by $350-400 to replace.
To open the drawer you need to turn the mains power off and then simply pull the drawer out with a little force. The lid seal is jammed shut because the lid seal actuator motors are locked after the power failed. Do not shut the drawer back as this will damage the lid seal. You will have to call a technician to replace the heater assembly and restore power to the drawer. Hopefully the top drawer is working ok.
Aug 01, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Mar 27, 2012 | JVC Audio Players & Recorders
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Soap drawer won't open
hi they normally just pull out.just take your time it might have wet powerder on the edges make it get stuck good luck
regards
shaun
Nov 28, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Panasonic dvd home theatre system SA-HT520. My 2 year old was playing with buttons on dvd player and now when i press open/close button it is saying locked and won't open, is there anything i can try...
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 29, 2011 | Panasonic Home Theater System System
ASKO 6021 washing machine, drawer locked
Reach under the drawer, right side and move the lock mechanism to he left. The drawer will unlock.
Mar 22, 2009 | Asko W6021 Front Load Washer
LG HT503PH Disc drawer will not open and displays "locked"
there should be a key synbol on the remote. press pwr off, then press the pwr on and the key button at the same time. The usual fault is the child lock has been activated.
Jan 05, 2009 | LG Televison & Video
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Disk drawer is locked
You have to reset the unit: While stopped, press and hold [ ] on the unit and [S10/ENTER] on the remote control for about 3 seconds until ?Initialized? disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Sep 23, 2007 | Panasonic SC-HT95 System
Stack-On 6-Drawer Steel Chest and Cabinet Combo Logo
213 people viewed this question
Top Stack-On Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Stack-On Hardware and Accessory Expert? Answer questions, earn points and help others
