Philips Blu-ray Disc Player with Wi-Fi - Black BDP2105/F7 Logo
P
Pat lynott Posted on Dec 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No audio i cannot get and sound when i connect my dvd player to my hi def tv. i do not have an hdmi cord. i am using the yellow 'video' cable.
spstephenjoh
Level 2:
Sergeant:
  • Expert 302 Answers
  • Posted on Dec 26, 2013
spstephenjoh
Expert
Level 2:
Sergeant:
Answers
302
Questions
0
Helped
39765
Points
595
You have to have the cable with three colors, yellow is video, white is one side stereo and red is other side. Plug into av on back of tv then select the av
How to hook up Cables
Depends on what kind of cables you use. If you use an HDMI cable, then you simply connect one end to the DVD player to an unused HDMI port on the TV. If you are using a 5 cable Hi Def cable then you connect the outputs of the DVD player to the inputs of the TV color for color Red to red, blue to blue, green to green and red and white cables for the audio. If you are only using a cable with 3 connections, then yellow is for video out from the DVD to component in on the TV and then the red and white cables for the audio.
tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
4answers
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
I HAVECONNECTED ALL MY SPEAKER WIRES,HDMI CABLEAND CONNECTED THE YELLOW AUDIO CABLE.POWERED UP THE DVD BOX BUT I ONLY GET SOUND FROM TV.the tv is a new 47'' LG.
If you are using HDMI cable you will not be using the YELLOW RCA plug sine the Yellow pug is for composite video. Analog audio uses RED (RIGHT) and WHITE (LEFT) for sound.
How exactly youhave the whole thing setup? through the receiver or just between the TV HDMI port and the HDMI port on the DVD player?
You will also need to setup the HDMI sound set up to send the sound through the HDMI cable or through the audio analog RCA ports.
More info needed. Hook up per DVD and TV user manuals
How to set up to using hdmi
#1 your tv would need to be hdmi compatable (have the appropriate plug on the back where all the inputs are located). For example I have a 60" Lcd HDTV and an xbox360 I attached the standard a/v (audio/video) red,white,yellow wires to tv and turned on the game console went into system settings and turned on the hd setting to 1080i for hi def resolution. Another alternative would be to connect console to your dvd player (most new dvd players will up convert signal from 480i or 720i to 1080i hd) and attach your hdmi cable between the dvd player and the tv to support the hd interface. Something I highly recommend is the jvc th c50 home theater surround sound when I play call of duty it has enough to knock stuff of our bookshelves and ******** the neighbors. Happy gaming
4helpful
Need to connect dvd player have yellow, red and white connectors
Red is right channel, White is Left Channel, and Yellow is video.  If you just got the TV and DVD player its a pretty simple setup.  Just look on the back of the DVD player and hook the yellow cord to video and hook the other end to video on your TV.  Now just plug in the red and white cords to the audio on the back of the DVD player and connect the other ends to audio on the back of the TV.  You can bypass these connections and just get a HDMI cable which has video and sound all in one convenient cord, but they cost more.  You just connect the cord on the back of the DVD player where it says HDMI and then plug the other end to the TV where it says HDMI.
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
2answers
Connecting DVD Player
Connect the DVD player using the audio/video cable (yellow,red,white) to the input on the back of your tv. yellow cable to yellow input and so on
4helpful
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
