Question about Acer TravelMate 517TE Notebook
Hp notebook turns off and on by itself
Hp notebook shuts off than it's turns back on by itself
How to fix the HP Laptop are shutting down by itself
Hi Walter, The link below is a YouTube video showing how to fix your lap top shutting down by it self, Also there's videos down the right side of the link that may help as well, By the way instead of using a straw I'd undo the back..........CHEERS..
Don panic Is your laptop shutting off by itself or slowing down during use
May 11, 2016 | HP Pavilion dv9000z Notebook
My hp pavillion dv 1000 shut down then turns back on but the screen is black and it reboots itself every 5 sec.
thats a trojan or virus in your laptop,i suggest u format or boot from cd/dvd rom with a compatible operating system disk(WIN7/XP/VISTA/2000),THEN U DO system repair..THAT IS IF U HAVE ANY IDEA ABOUT IT,IF NOT,TAKE IT TO UR REPIARMAN
Nov 25, 2010 | HP Pavilion dv1000 Notebook
Lap top will shut off by itself then come back on does this within five minutes of being turned on
What laptop do you have? Configuration?
Windows? Linux? Mac?
Did you install something recently?
Describe the question in more detail.
Jul 14, 2010 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: My Hp laptop turned off by itself and wont turn on...
Make sure your Notebook is not overheat if it is then you have to make sure the fan is working and have to work on the NB by placing it on a hard surface and also BIOS update will also help to resolve the issue.
if in case the notebook is not overheating boot to BIOS screen and check if the Notebook turns off by itself in bios if it does then its a hardware issue and you need to contact manufacturer to service the notebook
May 18, 2010 | HP Pavilion dv9000z Notebook
HP Pavillion DV 6000. Turned it on and it shuts
Is heatsink connected to this problem? (sic) Most probably not, it is more than likely a simple Driver problem. Try to startup in SAFE MODE, press F8 at boot time. If this works you could run a "System Restore" back to a time before it went faulty. Or troubleshoot from safe desktop.
Feb 10, 2010 | HP Pavilion dv6000z Notebook
My hp notebook just shut off,wont come back on
Sounds like a burnt out capacitor. Either on motherboard or power supply.
You can try taking out battery, press and hold power button for 5 seconds, put back in and try to turn on. If it doesn't turn on, then I'm afraid motherboard is bad or memory card is faulty
Nov 11, 2009 | HP Pavilion dv2610us Notebook
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? My HP laptop keeps shutting itself off after...
hi,
Please check for the exhaust,is it coming properly and check the bottom of the Notebook is it heating ?
If heating then this is the issue with the processor fan.
If the temprature is normal then check in BIOS(leave the system in BIOS mode for 8 minutes) if then also it is turning off surely this is the heating issue.
If above mentioned is not working please revert.
Feb 09, 2009 | HP Computers & Internet
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Acer TravelMate 517TE Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
