Question about Norcent Technologies Cameras
Says card locked
When I attempt to take a picture it says card locked
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Norcent Tech... Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Dec 25, 2013
Trying to take picture but it keep reading memory card is locked out. How to fix that problem?
We are assuming your camera uses a SD card.
26115945-215p5zdesqcnn1v3z4kj5yyc-4-0.png Check the switch and place it in un-lock position to write.
If this does not solve your problem, you can attempt this memory on another device and verify it works ok.
In a rare case, the SD card (also sd micro card) can be defective and cannot be repaired.
Mar 03, 2016 | Vivitar In Box Camcorder Dvr538 Hd
Format xd card error I bought new Fugifilm xD-Picture card, 1 GB, and putit in camera. Brought up format screen and attempted to format. All I got was "card error!". I thought the problem might be the...
Try formatting the card on your pc, connect the card to a card reader, open my computer find the card, right click format, try standard fat first and format. if that doesn't work try Fat 32.
Jul 16, 2008 | Olympus Camedia C-350 Digital Camera
How do you get card locked off
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 29, 2012 | Samsung Digimax 530 Digital Camera
I have a DMC-FS42 and the memory card is locked how do I unlock it Thank you!
The memory card may be physically locked. If you remove the memory card from the camera look at the side of the card. There is a small lock that can be slid up and down on the side of the card. Make sure the lock is off. If you cannot tell which direction is locked switch it and then try it in the camera.
If you have pictures on the card try to download them with a card reader first then attempt to format the card in the camera by going into the camera menu.
Mar 01, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
I have an issue with my cannon camera. I just came from holidays and took over 500 photos on my ''Canon IXUS 960''. When i connected it to my pc to see all my pictures but i got an error message saying...
you should try some photo recovery software, here are some programs you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Note: Before your pictures are recovered, do not attempt to save more files to the camera memory card in case the original files(your pictures) are overwritten.
Mar 14, 2010 | Canon PowerShot SX110 IS Digital Camera
How can I change the "protected card" so that I can once again take pictures - and how can I keep this from happening again?
Pull your sd card out of the camera... there may be a lock tab along the left side of the card (label facing you and metal tabs up) the lock position is labeled... you can change it with your fingernail... make sure it's unlocked...
Let me know if you're up and running...
k
May 29, 2009 | Fuji FinePix A201 Digital Camera
I can't import photos from memory card to computer
Reformatting will not help you and will lose everything on the card. Furthermore, do not attempt any repairs or data recovery until all other options have been exhausted. Have you tried the card in another Mac? Does a simple drag and drop action to your desktop work, or do you get the same or similar message?
Make sure the computer is hard-rebooted and attempt to import pictures from another card. If it fails, problem with program. If it succeeds, problem with card, but this does not preclude trying the above-listed options.
Paul Ronco
Jul 18, 2017 | SanDisk 4GB Secure Digital High Capacity...
Memory Card
Check to see if the lock tab has been put in the lock position. If yes then slide to the unlock position.
May 08, 2008 | Cameras
Locked memory card
Hey there ccmm1009, if you look on the side of the memory card, you should see a small brightly colored little tab. It should also have a small arrow with "lock" written next to it. Simply move it to the unlock position, and you are good to go. If this does not solve it, please respond with your exact model name and #, and I will attempt to help you further. Good Luck!
Feb 25, 2008 | Polaroid i532 Digital Camera
Cameras Logo
Top Norcent Technologies Cameras Experts
vwong
Level 1 Expert
mohamed salim shaikh
Mitch
Mitch
Are you a Norcent Technologies Camera Expert? Answer questions, earn points and help others
