Question about Jenn-Air JMV8208BAS Microwave Oven
If turned off it will not turn on - Jenn-Air JMV8208BAS Microwave Oven
I have a kitchen aid microwave and when turning on sounds like the bird chirping around the bottom of the unit.
Does it have the option to turn the turn table off if so turn it off and see if noise goes away if so turn table motor very common over time it will default back to on on next cycle
Feb 20, 2015 | Microwave Ovens
What is the probable cause of the fan turning itself on?
To diagnose i would check if the fan "always" turns on in the start of microwaving a meal? and or if it gets hot and then "always" turns off at a certain time?
if it always turns on and then turns off at a time such as 30 seconds, probably getting hot and over heating - replace fan motor
if it turns on for the first meal but then is off or on intermittenly probably a switch or wiring is loose.
Jul 03, 2014 | Electrolux Microwave Ovens
Why turntable will not turn
You either have a bad turntable motor, or else a bad (broken) shaft coupler.
May 08, 2014 | Kenmore Microwave Ovens
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
Nov 06, 2012 | Microwave Ovens
My rollers don't turn
may sound stupit but are the rollers clean and does the pice in the middle that turns them turn when its not in or is the wrong playe in there or your belt could be broken that turns it
Sep 28, 2012 | Microwave Ovens
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
Turn table doesn't turn
Is the plate engaging the drive?
Jun 15, 2009 | Kenmore 63792 Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
Not turning
r u putting heavy stuff on it? if not, then its probably how it is and u should exchange it.
Nov 27, 2007 | Tappan TMS062E1 Microwave Oven
Jenn-Air JMV8208BAS Microwave Oven Logo
24 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
