Question about Lands Phones
I WISH TO UPGRADE MY 2 BED FLAT ENTRY SYSTEM
I WISH TO REPLACE MY FLAT ENTRY SYSTEM WITH A NEWER UNIT BUT THE WIRING IS NOT THE SAME WHAT WIRES DO I NEED TO USE,IT IS AN AUDIO PHONE ENTRY WITH REMOTE DOOR RELEASE,OLD UNIT(FERMAX NR0208TN)4 WIRE NEW UNIT(EXTEL PACB401LC)THERE ARE SIX FLATS AND THEY ARE INTERCONNECTED I FOUND AFTER DISCONNECTING IT, THE FLAT IS ABOUT 40 YRS OLD THANK YOU,KEN. PS NEW UNIT CAME WITH ITS OWN REMOTE BUT I CANNOT FIND A SPACE FOR IT SO I NEED TO USE EXISTING DOOR PANEL,
kehalim
  • 55 Answers
SOURCE: ADF Document Jammed
Have you tried manually rotating the ADF wheel back and forth, sometimes the sensors are OK but the rotators lose grip.
Posted on Oct 23, 2007
  • 205 Answers
SOURCE: wiring on thermostat tl7235a1003
OK, here's my guess at this...I hope someone more knowledgable will confirm or correct me.
A line voltage thermostat switches the power to the baseboard heater. In other words, it's just like a wall light switch except it activates and deactivates based on the temperature.
I think your old model CT62 was wired exactly like a light switch. The hot wire to the light is broken then run to the wall switch and then back to the light so there's no neutral wire at a light switch box. This worked fine for your CT62 because it did not need power, it only needed to switch it.
The new model TL7235A1003 requires electrical power because it's programmable so you need both a hot wire and neutral wire at it's installed location. In addition you also need 2 wires leading to the baseboard heater so the thermostat can supply it's power.
I believe L1-L2 are to be connected to the hot/neutral wires, and the Load wires go to the baseboard heater.
If I am correct you will not be able to use this thermostat without some re-wiring.
Good luck.
Posted on Nov 27, 2007
  • 43 Answers
SOURCE: How do I wire a new phone jack ...
The new jack should have the same color code as the wires.
All the red's go together on one screw, and the green's as well.
Posted on Feb 13, 2008
  • 38 Answers
SOURCE: new phone wire from box to home need diagram to show how to
The phone company should make that connection. Use a phone jack assembly with alligator clips to find the dial tone. The first line color should be a pair, blue&blue-white, 2nd line, orange& orange-white, then green followed by brown pairs which would be 4 line numbers in that color code order. Each line is just a single pair. Thank you. Jer
Posted on Feb 25, 2008
playaway
  • 18 Answers
SOURCE: wires from the wall are
Take a look at this image:
0d5b58e.jpg Notice that the Line 1 will typically present on pins 3&4 and Line 2 on 2&5. I would think in your case Black/Blue is Line 1 (3&4) and Yellow/Black is Line 2 (2&5).
If you have a 1 line phone and only have 1 line active, then typically blue and blue/white can be connected to the Blue and Black of your Jack. If this doesn't work, switch with the Yellow and Black.
Please let me know if you have further questions. Good Luck!
Posted on Aug 11, 2008
Wiring diagram for sunquest pro 24 tanning bed
I do not have a diagram, but the contactors are really simple. You have 2 power switches on top of contactor and 2 wires going to the coil. There should be 4 larger wires on top, 2 in and 2 out.
If any of the crimp-on wire fasteners are blackened, then have a trained technician to replace the fastener. If bed comes on when pushing down on contactor with a plastic ink pen, then check the timer by turning on the timer and checking the voltage at the Main Relay Coil. If no voltage, then the timer is bad.
Jul 31, 2012 | Wolff Sunquest Pro 24RS 220 Volts
I am having an 6 and 20 error !What should I do to fix it?
11_24_2011_4_20_49_pm.jpgRemove flat bed(remove screw under control panel sticker, remove control panel, remove flat bed screws) take out scan head unit, observe any breakage in mechanism as shown in the snap shot,if found breakage replace scan head mechanism,if not replace scan head...clean flat bed glass neatly, fix all back.
Nov 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Fuel sensor does'nt register properly on the cluster, replacement of fuel level sensor procedure
the fuel sending unit is inside the fuel tank and is part of the fuel pump module, you either have to remove the fuel tank and then turn the fuel pump module locking ring to release the pump unit, and replace the in tire unit you may have to replace the wiring plug end most of the older pumps have been replaced by a newer style pump that uses a newer style plug, or you can remove the bed to get access to the fuel tank.....HAVE FUN
Nov 29, 2010 | 1996 Chevrolet K1500
Ugrading to a newer system with higher performance specifications
You can upgrade you memory to 2 x 512MB DDR PC2700 333MHz, and install pretty much any size 2.5" IDE hard drive you wish. Installing Vista will make this machine very very slow. Windows 7 would be better as it uses less resources. Ideally XP Pro would be better suited based on this boards specifications.
Jan 10, 2010 | Compaq Evo N1000C Notebook
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
LHJ001 WIRING
I have the 1995-97 Lincoln Continental Alarm, Remote Starter, Keyless Entry Wiring, review it:
Hope helped.
Oct 30, 2009 | 1996 Lincoln Continental
Brake lite stuck after heavy load in bed.
you probably pinched the wires for the brakes between the bed and frame, which would give you a short. try getting under the truck and tracing the wiring from back to front. it will be on the drivers side. if you find where it is pinched at it would be best to replace atleast that section of the wiring
Aug 11, 2009 | 1995 Nissan Pickup
Our state agency purchased 300 Nuvis for our police cars. I am the training officer and am being asked what benefit otaining the $70 upgrade would be. Is this urgent? Is is needed? Could we get a free...
It depends on how long you have had them.
I have heard that a buyer is entitled to a free upgrade if the unit is new and the upgrade is requested within a certain amount of time.
Apparently there the firmware in the unit records when the unit first obtains a satellite lock and that date is is used to determine how long the unit has been in operation. I'd check into it right away.
The problem is you have so many units and it takes about an hour to upgrade each one. So, its not going to be a quick process.
You need to see what map is already on the unit by selecting the tool icon, then system, then maps and then "map info".
The 2010 maps are already out. Newer maps means you unit is more up-to-date with current roads that have been added.
No it is not urgent but if you can get it for free, then you may wish to consider it.
- Jim
SHARCNET-USA
http://www.sharcnet-usa.com
Aug 11, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
2000 sears craftsman garage door opener
#1 wire with red trace –
#2 all white wires with no trace
#3 wires with black trace
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
IBM ThinkPad R40 Intel Centrino Upgrade to Intel Core 2 Duo?
According to system specs your system is not compatible with the Core 2 Duo or Centrino Core 2 Duo. To upgrade to those chips you would need to replace the motherboard with one capable of running those chips. If you decided to do that you would almost surely need new RAM as newer boards use newer technology. By the time you did this the upgrade would not be cost effective. Hope this helps & please remember to rate my answer. Thanks.
Feb 03, 2009 | IBM ThinkPad R40 2722 Notebook
Lands Phones Logo
67 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
