Question about Jenn-Air JMV8208BAS Microwave Oven
Power outage and now won't work - Jenn-Air JMV8208BAS Microwave Oven
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
Will not power up after power outage
it contains two fuses one of 10 Amps and other for 500mA.
Replace 10Amps fuse with same type and rating.Best thing is to take this fuse and show it to the sale person of electronic shop.
Before you touch any parts of the microwave oven please disconnect the mains power chord and never touch the main power capacitor as this contains very high voltage even after disconnection.
Mar 24, 2014 | Whirlpool Microwave Ovens
No power dead
power outages cause power surges and will damage electronic control boards. I suggest replacing the Control board and checking the interlocking door switches. Whilst inside the microwave check the magnetron for discoloration around the magnetron horn or gun as it were. If it don't look clean and new, otherwise burnt it's bad !
Feb 06, 2014 | Sharp Microwave Ovens
Power Surge - GE Microwave
see this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Jul 12, 2013 | Microwave Ovens
After a short power outage, I have clock issues.
this a problem with the clock , but the microcontroller can be defective by the power outage, see the diagram . how the microncontroller has the control for any equipment.
IN SHTE M.CONTROL BOARD CAN BE DEFECTIVE. go to the repair shop Tv FOR FIX IT. God bless you
Jul 19, 2012 | Microwave Ovens
My amana model number amv1150vas is not working after a power outage
Unplug for 60 seconds to see if it will reset, if no! the fuse in the microwave has opened/ or if the model is the new type, it is the keypad control board or smart board.
Apr 05, 2012 | Amana Microwave Ovens
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
Can not reset after power outage
If display is on and you cant reset, the board has been damaged during the power outage. The current shoots up over the safe limit and does the damage. need to replace board and put a surge plug on line
Sep 15, 2009 | Kenmore Microwave Ovens
I have an JVM 1630,31 it stopped working after a power outage the house got cold and I turned the stovetop on for 5 minutes did I burn something out or was it because of the power outage? I replaced the...
Below refers to the manuals which all contain the wiring diagram.
Microwaves:
 Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel.
http://www.geappliances.com/service_and_support/faqs/
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Jenn-Air JMV8208BAS Microwave Oven Logo
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
