Question about Ruud Handler Air Conditioner
Rcba 3765gg17 i need to know how many tons is my unit
3 Suggested Answers
SOURCE: Need to change a filter, can't find it?
I can not find the location of the filter!
Posted on Jul 26, 2008
  • 39 Answers
SOURCE: Ho many ton's is this Ruud air Conditioner
3 ton
Posted on Sep 01, 2012
Dealing with a corsaire RCBA 3765GH17 this is a 3 ton unit right?
right --now what is your question
comment to get answers
Oct 16, 2015 | Heating & Cooling
Rcba 4882g how much is it to replace the central AC condensing unit
This will be dependent on the capacity (tonnage or BTU/Hr) of the condenser, its location and how much refrigerant will be needed to added / replaced - plus the labor to do it. A typical 2 - 3 ton residential system (air handler / condenser - no duct work, etc.) can run $2k and up.
Jul 04, 2014 | Rheem Heating & Cooling
I have a rheem classic 90 plus rcba 3765gg17 in my condo. What is the filter size?
Mike I would contact Rheem directly or just take it out and go to a store and match it up
You could do a search but think the other two ways will be a lot faster
Oct 19, 2013 | Heating & Cooling
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
I have a 1995 ruud Achiever 10 heat pump with a RCBA 4882G 4 ton W Coil. We are replacing the coil because it has leaks. Should we also replace the compressor which appears to be operating normally?
Yes, you will have to replace the condenser also...
The reason is because the old unit was a R-22 unit and the new coils will all be for R-410A refrigerant...
You cannot mix the two and one will not work right with the other.
So... yes, you do have to change everything and clean the refrigerant lines before using them also...
heatman101
Apr 16, 2011 | Heating & Cooling
Outside fan runs constantly Aux Heat only 50%
Let's start out by your statement that the fan would not run, then you changed the contactor, not it won't stop running.
I believe, based on your info, here's what you need to do. Kill power to the unit. The 2 wires bringing power to the outdoor unit should be on the top 2 terminals. The 2 fan wires should be on the bottom 2 terminals. This is providing that the contactor is mounted Vertical. The could be an outside chance that the unit has a short in it and you are getting voltage feedback somewhere.
Take another look.
Dec 30, 2009 | GE Zoneline AZ55H09D Air Conditioner
I have a Rheem System Model number rcba-3765GG17 Serial number M1201. How would you turn the heat on?
At the low voltage terminal where thermostat wires atttach, and go to stat and ac unit,
there is R red, W white, Y yellow, G green, C common
red is hot white is heat, yellow is cool , green is fan
jumper red to white for heat
Nov 28, 2009 | Heating & Cooling
Found it, I could kick myself for not reading all the labels on the air handler unit itself.  If you look in the middle of the unit where the power is connected you'll see a small door that says filter access.  Two thumb screws hold it in place and behind it is a washable black mesh filter, slides out.
Jul 24, 2008 | Ruud Handler Air Conditioner
Heating & Cooling Logo
32 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
