Question about Whirlpool WTW6400SW Cabrio Washer
Start button on whirlpool cabrio washer works intermittently
Power and start button work intermittently
tzweeb
  • 318 Answers
SOURCE: LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Posted on Jan 30, 2009
  • 82 Answers
SOURCE: Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Posted on Jun 27, 2009
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: start button not working on whirlpool cabrio
It sounds like your thermal fuse is out. You can check it for continuity with an ohm meter, make sure your dryer is unplugged first! Or you can take the wires off the thermal fuse and use electrical tape to tape them together to see if it will come on.
CLICK HERE for the TECH SHEET on your washer... and HERE to see the thermal fuse.
Sometimes the plastic start button can break a little tab off the back as well, so check it as well.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool cabrio washer keeps flashing code F50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Posted on Sep 28, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
    Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
    check these one by one.
    Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
    Push start button on control panel - machine does not start
    only 2 things can cause this.
    1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
    or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
    of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
    Jan 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool WTW6400SW Cabrio Washer Logo
    14 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
