Mordaunt short ms409w subwoofer rear panel removal
After removing all the outside screws the rear panel will not come away easily. I don't want to damage it by forcing it. How do I remove this panel.
Thank You.
  • kazndave May 28, 2009
    Take off all the outside screws and the 4 just inside the outside screws. Use a sharp strong blade (I used a paint scaper blade and it's holder - it looks like a large razor blade) to prise any part of the edge away then use any flat lever to go around the whole edge. There is a slightly stickey rubber gasket that stops the panel coming away easily. Use a piece of cloth to protect the cabinet. There is a plastic 'box' inside and the wires inside for the speaker and the front L.E.D. are quite short and are cable clamped on to the plastic box. The led wires can be unclipped from the pcb, but I had to cut the speaker wires.................good luck.
    Problem Solver:
  • 17 Answers
You don't have to cut the speaker wires.
Under the foam wrapping is a connector - just unclip it!
Posted on Nov 29, 2010
How do I replace the tweeter on Mordaunt Short Avant 906i speakers?
Hi - Just reading your problem with the 906's and removing the front cover to replace the tweeter. Did you ever solve the issue? because I tried today and I can't budge the silver cover once the screws have been removed. My email address is chris.clemons@btinternet.com if you can help - thanks
Feb 16, 2012 | Mordaunt Short 906 Rear Speaker
Hi my name is Ben. I have a Mordaunt Short home theatre system which is probably 6 yo but has had very little use. On standby mode, the 309W sub started to make a buzzing sound with intermittent louder...
It can be repaired. A transistor shorted and possibly some resistors burned open as well. This is due to an overload causing the transistor to drive hard creating heat and eventually shorting out. The transistor needs to be isolated, removed, and replaced as well as the resistors.
Nov 12, 2010 | Mordaunt Short 309W Subwoofer
309i sub not working
hi ,
2 things to do
1 - the power amp has fail and will need to be looked at
2- your amp could have a sub output faillure
Jul 14, 2010 | Mordaunt Short 309W Subwoofer
I need to replace the woofer in mordaunt short 906i but have been having problms removing the front aluminium cover. I have removed the screws but it does not come out. any suggestions? Thanks
I don't have the solution for you but I know someone who very likely does. You can message a user on the sound and vision forums by the name of irritateguy.
Jun 14, 2009 | Mordaunt Short 502THX Main / Stereo...
How to connect a mordaunt short ms907 subwoofer?
I guess you don't have the owner's manual for this?
You can get it here:
MS907 Subwoofer manual
The manual contains connection info.
Apr 27, 2009 | Mordaunt Short MS-308 Subwoofer
Mordaunt short 906 tweeters
 i have found that partexpress is a good place to replace speakers and much more
Feb 24, 2009 | Mordaunt Short 906 Rear Speaker
Mordaunt short ms409w dead - both fuses blown
This kind of thing is impossible to "fix" remotely.
Check the bridge rectifier first then suspect the Class D output module on the heat-sink. The main smoothing capacitors, I have had one go completely open circuit but I wouldn't suspect one of going short circuit (Would only blow one fuse).
I have not been able to find any circuits for this model as I have two of these subws myself.
Anyone found any?
Frank
Nov 15, 2008 | Audio Players & Recorders
Mordaunt Short Avant 309i subwoofer set-up
Lots of ways. To set it up properly you will need a decibel meter, Radio Shack makes a nice one. With the meter volume can easily be set as well as phase. I'm assuming frequency is the crossover frequency, generally set at 80Hz. This one involves some trial and error as I am not familiar with your speakers. Don't know much about the notch filter. A good resource for setting up subs can be found at: http://www.hometheatershack.com/forums/bfd-rew-forum/index3.html
Jun 18, 2007 | Mordaunt Short 309W Subwoofer
809 people viewed this question
 Grubhead
Grubhead
