Question about BAFX Products Camping, Backpacking & Hiking
I accidently pulled apart the handle section from the midsection. How do I fit them back together?
  • 49 Answers
SOURCE: My door handle came apart and now I have the
I assume the latch mechanism is still intact... the piece on the edge of the door that locks inside the strike plate when the door is shut -- if that's the case the only thing left to do is align the two knobs, one on iether side of the door, making sure the shaft goes thru the latch mechanism properly (it only fits thru one way) and then sandwich it tightly to the door and tighten it together with a phillips head screwdriver... some kwikset locks require you to turn one of the knobs to get the bolt heads to seat properly.
I'm not familiar with the chelsea model but they are all very similar... if you have more than the 2 knobs with a long shaft on one then chances are the solution above does not apply... you probably will have a knob with shaft and then a flat plate with holes, a finished plate and a plain knob... in this case align the knob and shaft thru the latch mechanism, place the plate with holes on the other side of the door and twist it slightly so the bolt heads lock in and tighten the bolts to the plate... now snap the finished plate over that and push the knob over the exposed shaft that remains... you'll need a flat head screw driver to lock the knob on where a small spring loaded piece fits into a cutout on the handle...
that's about the best I can explain it.
Posted on Sep 09, 2009
  • 685 Answers
SOURCE: Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Posted on Jan 01, 2010
  • 685 Answers
SOURCE: How to take apart manfrotto monopod 682b?
You can loosen the top screw on the top leg lock. Just enough so you can pull the bottom legs out of the main tube. Ths shoud shorten it up a bit. You wil need a small spintight or wrench.
Posted on Jun 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: need a diagram on door handle how 5 pieces fit together
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
  • 316 Answers
SOURCE: What are the components in the handle of a Ryobi RHP 410 pressure washer?
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions.thankyou. ``
Posted on Feb 19, 2012
Testimonial: "Thank you for the insight. However, seeing that the pressure washer belonged to my mother-in-law, who now lives with us, and because I have a bigger and better pressure washer, and because I had not received a response to my question for some weeks, Mum suggested I scrap hers, which I have now done. Nevertheless, I will continue to drain my pressure washer after each time I have used it, which is something I always do anyway. Thank you again. Graeme."
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
Jan 28, 2012 | Ryobi Garden
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
The power was not copming on becaise the little metal contact at the bae of the tower was nopt making connection to the silver power post. I removed the top and the swivel midsection to rebend the metal...
Hi the tomato m,
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 24, 2010 | Ionic Pro TURBO Air Purifier
My mover took it apart and I cannot put it back together correctly so net fits the hoop to hoop
The push handle mechanism is comprised of two pieces. Attach the bottom piece first, then the top one. You will need to thread the pull rope through the guides in order to make the handle accessible from the top or middle of the push handle. Make sure that it is right side up so that the throttle and the self propel guide are in the correct positions.
Take care.
Oct 10, 2010 | Arcade Toys
Pulled of doorknob, all the peices fell out and now i cant put it back together
If this is an inside door from an old house, just take another one apart very slowly to see how the pieces fit. If this is an an outside door from a newer house, you might want to just buy a new lockset and follow the directions carefully. I assume you took it apart because it wasn't working anyway.
Jan 04, 2010 | Top Knobs M826 Door Pull
Dishwasher makes a loud grinding noise when running.
Start by pulling out the lower rack. Then pull the nut off the top of the lower spray arm. then remove all of the visible hex head screws. lift up on this section. this should expose another level of hex head screws, then they should be removed and this section should be lifted up. once you reach the chopper blade, remove the obstruction, and put back together.
Mar 13, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
How do I replace tailgate handle
I just finished replacing mine. It took about an hour. Here's my step by step.
1. take off the two outside bolts on the inside of the tailgate behind the handle.
2. Now gently pull off the cladding around the latch. It is still held on by two christmas tree style holders.
3. Tie some long ropes to each of the two rods that the handle pulls together. You don't want them getting away from you.
4. Now free the rods from the plastic clamps. This is the point of no return. Mine would not go back together. A small screw driver shoved in from the end along the seam will pop them easily.
5. Now remove the remaining 3 T40 bolts on the back of the tailgate.
6. The handle assembly is now free to come out. Hold on to it as you lift the tailgate back up. Don't shut the tailgate all the way.
7. Work the old handle out. I did not take any of the cladding off. It took about five minutes of gentle manipulations to get it out. I did have to pull on the metal tongue that comes up right in front of it.
8. Pop the replacement plastic clamps into their corrent places in the new handle. Hinge side down. Don't fasten them.
9. Put the new handle in the same way you took the old one out.
10. Attach with the 3 T40 bolts. Dont fully tighten, just snug. I would recommend some blue loctite as well.
11. Now shut the tailgate so that it latches. Place the pull rods in the plastic clamps and fasten them. Don't pull on the rods, just put them in the clamps.
12. Your door should work now. Try it a couple of times. Pull on both sides of the tailgate to make sure each is held tight. If so, tighten up all the bolts, put the cladding on, and your done.
13. If your door won't latch, the rods are being pulled together too much. Undue the plastic clamps, push the rods apart and reset them in the clamps.
Nov 06, 2008 | 2005 Chevrolet Avalanche
Mitsubishi Projection TV dis-assembly
When I took mine apart, I had to unscrew all the screws on the pegboard, then there are some screws along the midsection on both sides. Other than that, there weren't any cables or anything to be leary of. It was really pretty easy. Hope that helps.
Dec 19, 2007 | Mitsubishi WS-65905 65" Rear Projection...
Camping, Backpacking & Hiking Logo
93 people viewed this question
Top BAFX Products Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a BAFX Products Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
