Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
SELF CLEAN DOES NOT TURN ON.wHEN I PUSHTHE SELF CLEAN BUTTON ON,IT TURNS ITSELF OFF IN A COUPLE OF SECONDS
  • Frigidaire Master
  • 8,220 Answers
The door has to be latched. Bad door latch assembly maybe? Will it bake ok? Getting any codes? E-5 is bad door latch I believe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 26, 2013
How do I turn off?
Just open the oven door and you'll see a button that the door actually pushes against... with your finger hold the button in and turn the oven on to the self clean cycle... While still holding the button wait a few seconds and then turn the self cleaning cycle off, this should disengage the door latch... Always keep the button engaged until the self clean cycle is off...
Mar 25, 2013 | Ovens
MY R.C.A. MODEL 20F420T WILL NOT STAY ON. TURN IT ON IT MAY STAY ON 3 SECONDS TURNS IT SELF OFF TRY AGAIN IT MAY STAY ON 2 SECONDS BACK OFF THANK YOU ????
The first couple of seconds of operation, most TVs are doing some self-test and if something has failed making full power on dangerous (for fire) they will shut down. Either a major component in the horizontal section has failed or the main power supply itself is defective.
Dec 05, 2010 | RCA 20F420T 20" TV
Tv turns itself off
do the self test the set has.
when green light (power) comes on and then goes off, press and hold BOTH the Menu and Input buttons for at least 5 seconds and release both buttons on the front of the set.
The power light will display a error code: for example 2 blinks, a pause and 2 blinks (this is the most common one) and it will repeat the code about 5 times.
To get it to repeat it you have to unplug set, plug it back in and turn it one and when it fails repeat the check.
Let me know what error code you find and I will tell you what may be wrong. I hope it is 2,2 as it is the least difficult to resolve.
SD TECH
Jun 16, 2010 | Mitsubishi WS-55809 55" Rear Projection...
It wont stay on it cuts itself off and on the power button has t
This seems to be a problem in the Power Supply I would think. Either that or a fault that is overloading the PSU.
This means a trip to the repair shop.
Make sure ya get a firm "Quote" for tha fix before proceeding.
Jan 20, 2010 | RCA HD56W58 56" HDTV
Camera turns self off
Take a Q-Tip "dampened in rubbing alcohol. remove the battery and clean the two or three contacts at the base of the compartment.
Aug 30, 2009 | Polaroid i835 Digital Camera
My jensen pauses and turns itself on
i had the same problem with my jensen phas linear, i called the factory and they told me the lens is probably dirty and to try and clean it, well i did, actually cleaned it a couple times then put the movie in and it has worked fine all day today. make sure you get a good brand cleaning disc, not the 99 cent store kind, i bought mine for about $9 didn't even have to put any cleaning solution.
Jan 12, 2009 | Jensen VM9510 Car DVD Player
I have a hp pavillion entertainment laptop and i try the power button and the computer turns on but after a couple of seconds it turns it self off and then trys to turn its self back on again it wont get...
try hitting F8 before windows attempts to load to enter the boot manager, from here you should select last known working configuration, if that fails, do the same except boot safe mode
Feb 13, 2008 | Computers & Internet
Samsung rear projection tv has multiple images with differnet colors
The auto self focus screws up if the picture does not remain constant or close to it while focusing. It is designed to self focus every fifteen minutes. Go to menu and then setup and turn the auto focus feature off. I have had mine off for the past year and have had no problems. If you slide the bottom portion of the remote down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button during a scene and then hit the self focus button. It should align back up and may take a couple of tries. (If you have an aftermarket remote, just enter the menu and then setup and you can activate the self focus feature, just don't turn it to auto focus!)
Dec 31, 2007 | Samsung HC-P4752W 47" Rear Projection...
Powers on but turns it self off after 15 seconds.
CHECK FLYBACK TRANSFORMER LEADS FOR BAD SOLDER JOINTS, HAVE REPAIRED SEVERAL WITH SAME PROBLEM.
Dec 02, 2007 | Samsung TXN3071WHF 30" TV
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
50 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
