Question about Vision Fitness Exercise & Fitness
Treadmill keeps stopping - Vision Fitness Exercise & Fitness
Keeps stopping. I turn off power and restart but it stops again after a few seconds. How can I reset it to quit stopping after a few seconds.
Hope the speed sensor have some problem may dust on it or the treadmill need lubrication. Most of the treadmill stop after some kilometres reading indicating that its time to lubricate it. After lubrication you have to reset the counter.
check the link bellow using the search tab find out details of NORDICTRACK A2350. and follow those instruction.
www.electro-medical.blogspot.com
Nov 01, 2015 | Nordic Track NordicTrack A2350 Pro...
Incline stuck at 12
please follow this steps and fix it. Merry Christmas
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 18, 2013 | Nordic Track NordicTrack - E 7.5
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
·3
Dec 09, 2013 | Horizon T203 Treadmill
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you
Instructions 1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Nov 13, 2013 | Cadence Exercise & Fitness
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Nov 03, 2013 | Proform 695 LT Treadmill
Fitstride t920 treadmill faults
Reset the machine follow this steps and fix it. God bless you
· 2
· 3
Oct 07, 2013 | Exercise & Fitness
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Factory reset code
follow this instruction and reset. God bless you
need replacing, or move on to the next step.
  • 2
    treadmill.
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2Z4hlSTfH
    Jul 15, 2013 | Landice L7 LTD Executive Trainer Treadmill
    The belt on my treadmill keeps slipping and i wanted to know how to stop it ...
    hi,
    You have to adjust the treadmill belt. Just watch the following video to do the same.
    OK
    Sep 01, 2011 | Treadmill Doctor Weslo Cadence Dx10...
    The treadmill keeps shutting off and display code reads "System Initializing"
    Check magnetic safety with lanyard,if magnet is not secure it can turn on and off. Also check plug at outlet. And emegency stop button , if you start treadmill and tap around e-stop it should keep running
    Nov 23, 2009 | Life Fitness 9500HR Next Generation...
    Exercise & Fitness Logo
    35 people viewed this question
    Top Vision Fitness Exercise & Fitness Experts
    Andrew Taylor
    Andrew Taylor
    rattack1511
    Level 1 Expert
    ray gallant
    Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
