Question about Keystone Heating & Cooling
Keystone furnace How to turn on furnace
    Scholar:
  • 45 Answers
Kim, Can you give me a model number of the Keystone Furnace you are trying to control?
Posted on Dec 31, 2013
HI we bought our first trailer a couple of months ago. It is a 2010 Keystone Outback 301bq. I can't find the water pump location or how to access the water heater. Any help would be appreciated.
One way to locate the water pump is to turn on a facet and then turn on the water pump. You should be able to hear it run as it tries to "catch up" on water flow/pressure. Look where the sound comes from. You can find the water heater from outside the RV by looking at the walls for a access door that has a screen on a portion of it. This will be the location of either the water pump or the furnace. If furnace, look for another such door.
Oct 10, 2016 | RVs
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Nov 19, 2014 | Office Equipment & Supplies
What to do with my furnace... When I turn it on it won't ignite, does anyone know how to fix this?
If it runs then there several things that could be wrong with it. one there might be something blocking the air flow which won't let it ignite usually mud dabbers like to build nest in furnace vents and intakes look in the vent with a light and see if this is the cause.
Aug 29, 2014 | Keystone 2010 Cougar 324RLB
Where is the furnace breaker
Is the pilot light lit? There should be a valve that turns the gas off at the furnace itself. This valve is for the pilot lite There is no breaker of sorts but rather a sparker that lights the furnace. If the furnace does not light there is a small 12 volt valve that shuts off the gas to the furnace but not to the pilot light. Also make sure your 12 volt system is connected and operating. It wont work without it as it operates off that system not 120V. The same goes for refrigerators, the will not function with the 12v system disconnected
Apr 13, 2014 | Keystone 2013 Hideout 32FLTS
Keystone not working
Manual: http://www.mitsubishi-presentations.com/wp-content/files_mf/mitsubishi_manual_xd250ust.pdf
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
I have a new keystone hideout with dometic single zone lcd thermostat when i put it to furnace the ac fan comes on at same time but when furnace reaches temp. ac fan just keeps blowing cool air?
Obviously wired wrong. I will assume it is still under warranty? If you only recently picked unit up, I would also question the quality of the PDI performed. ( Pre Delivery Inspection) Have you tried to contact dealer you purchased it from?
Oct 14, 2012 | Dometic Rooftop RV Air Conditioner
How do you change the lamp in a mod # 980Z keystone projector
There is a black and silver knob under the keystone label( right above the automatic label ) on the side of your projector. turn this knob counterclockwise to loosen the covering over the housing unit for the lamb. once the knob is loosened lift the housing unit off of the side of the projector. You wlll see the enclosure where the lamp fits into beneath it.
Make sure the power is off for your projector while doing so. Screw the lamb into the enclosure , then replace the covering and screw the black knob in clockwise until it tightens.
Sep 21, 2012 | Office Equipment & Supplies
The projector comes on.but there is no picture.lens not opening
Press and hold the two Keystone buttons on the top of the projector. Turn the projector ON and continue to hold down the two Keystone buttons for 15 seconds.
Release the Keystone buttons.
Turn OFF projector.
Turn ON projector, lamp should strike.
Sep 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
Once the projector is plugged in there is no picture. The projector comes on but the lens doesnt open
Try doing a manual reset by depressing the two Keystone buttons and turn power on. Hold down the two keystone buttons for 15 seconds, then release and turn projector OFF.
Turn ON projector and it will be reset.
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
Heating & Cooling Logo
81 people viewed this question
Top Keystone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Keystone Heating and Cooling Expert? Answer questions, earn points and help others
