Question about HP HEAT SINK
My heat sink clips on this plastic piece thats screwed into the mother board one of the taps broke off and the heat sink fan combo falls off the mother board and the computer over heats. what is this plastic piece called
  • 77 Answers
Those r called as Heat sink Clip u can find in any radio shack or any HW Shop. make sure that befor u put the HeatSink put the Thermal Gel.
Posted on May 17, 2009
Bad processor on my hp compaq
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
The "CPU" or central processing unit, otherwise known simply as "the processor," is the primary "brain" of the computer.
Processors are very finely engineered components that are not repairable.
But replacing a failed processor is an option for the owner of any model Compaq Presario desktop computer.
Just check with HP/Compaq for the correct size and speed of processor for your motherboard before purchasing a replacement.
Turn off the computer and disconnect all cables.
Remove the cover.
Lay the computer down flat.
If there is a plastic hood covering an exhaust fan, remove it by pressing in on the indicated release tabs.
Examine the processor assembly.
The processor is a square chip that is covered by a metal heat sink with fins.
A fan will often be mounted on top of the heat sink; unplug its connection to the motherboard.
Two clips usually secure the heat sink assembly to the top of the processor.
Gently press down and slightly away on the flat end of a clip to release it.
Avoid using a screwdriver to release a clip a slip could scratch the motherboard.
Release the clips and gently remove the assembly.
The heat sink should separate, leaving the processor behind in the chip holder.
Clean the bottom of the heat sink.
Use a paper towel and a dab of solvent cleaner to remove the old thermal paste.
Set the clean heat sink aside.
Lift up the lever to unlock the old processor and remove it from the pin mount.
Insert the new processor chip.
Align the pins on the processor to the "cut off corner" or dot on the pin mount.
The processor should drop into the pin holes easily.
If the processor won't drop in easily, check the pin alignment.
Once the processor is inserted correctly, pull down the lever to lock in the chip.
Apply thermal paste to the bottom of the heat sink.
Apply enough paste to cover the area of the small gray rectangle on top of the processor.
Apply the paste with a spreader made from a piece of flexible plastic.
Spread the paste evenly to a thickness of two sheets of paper.
Check the heat sink mounting alignment and lower the heat sink onto the top of the processor.
Reinstall the mounting clips.
Reattach the heat sink fan to the motherboard if necessary.
Plug in the computer and monitor and boot.
If the machine won't boot or it emits warning "beeps," unplug the power and monitor, and troubleshoot your work until the computer boots successfully.
Shut down again and replace the exhaust fan hood.
Close up the computer and reboot.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hope this helps
Nov 11, 2012 | HP Compaq dc5100 Microtower PC Desktop
Tip
PS3 (Playstation 3) Yellow Light Of Death REPAIR GUIDE
Disclaimer: if your PS3 is still under
warranty then please send it back to them for repair.
DO NOT Try this repair IF IT IS STILL UNDER WARRANTY.
This Guide is for the repair of *********** boards only and
will not repair your power supply or read errors.
In this guide there is no guarantee you will fix
your ps3 and by following this Guide YOU take on full
responsibility for any damages caused by following this guide.
Tools needed
Heat gun .
Isopropyl alcohol.
Vacuum cleaner or compressed air can.
Phillips screw driver.
Flat Head screw driver or slotted torx bit.
Artic Sliver 5 (Radioshack)
1. Remove warranty sticker and rubber foot that’s
positioned above hard drive bay.
This will invalidate any warranty.
2. Using a small flat blade screw driver or slotted torx bit,
unscrew cover plate screw.
3. Slide cover plate towards the left until it stops and lift
off.
4. Remove all Phillips screws marked noting size and
position.
5. Hinge case towards you until disengaged and then tilt
towards the left. See below.
6. Remove ribbon cable by carefully lifting black part of
connector (locking tab).
7. Lift/tilt blue ray drive towards the right whilst
disconnecting power cable and the large ribbon (lift tab)
underneath.
8. Remove 5 screws and the earth wire screw on psu, and
unplug connector plug.
Before removal of psu unplug small bnc connector (black
wire) and remove tape on side of psu, now lift off psu.
9. Now remove the wide ribbon from connector (lift tab)
unscrew the four screws on the Bluetooth board and
remove.
10. Remove hard drive cover,
11. Unscrew blue hard drive screw and disengage hard
drive by sliding towards gap in the bay. .
12. Remove hard drive,
13. Unscrew 4 screws holding the bracket, on/off and
eject control panel.
Remove small ribbon (lift tab) and remove control panel.
14. Unscrew 8 screws,
15. Lift enclosure out of plastic base,
16. Now unclip black rear panel and remove.
17. Unscrew 4 screws and remove sprung brackets,
18. Lift of metal cover plate whilst allowing ribbons to
pass through gaps in plate without damage, see below.
(Taking note where heat sink rubbers are positioned).
19. Supporting fan assembly turn board over, remove
fan power connector and fan,
20. Remove 2 screws holding plate to hard drive
connector and unplug battery connector. See above.
Now remove plate.
21. Clean off old heat sink compound from the 2 main
processors using Isopropyl alcohol Or Artic Silver remover Faster Than alcohol)
making sure all traces of the old heat sink compound has gone.
22. Clean both touch plates on bottom of fan/heat sink
assembly with Isopropyl alcohol until all traces of the old
23. Now using a vacuum cleaner or compressed air
blower get rid of all dust build up in the case and on all
component parts of the ps3 (pay special attention to the
fan assembly and heat sink fins(MUST BE CLEAR OF
DUST).
24. Place the ps3 mother board on a flat heat resistive
surface (kitchen work top or melamine shelf will be fine).
25. Turn heat gun on and set temperature to 350 deg
and the fan speed to low (to high and it will move the
surface mount bits).
Allow gun to get up to temperature before
continuing!!!!
Note (There is two Large Square Chips in the Middle of the board these are your CPU and GPU they both have two Black Rectangles Right Next to them. These are the Memory Chips. These are the only things you will be Heating Up on top and Bottom)
26. Using a circular motion hold heat gun over areas
outlined below (keep heat gun an inch above
board/components at all times).
27. CPU side first.
. After 15 to 20 seconds move onto the next area.
28. Once all marked areas have been heated/reflowed
on the mother board LEAVE for at least 10 to 15
minutes to cool.
(DO NOT MOVE MOTHER BOARD WHILE COOLING).
29. A popping noise may be heard during cooling, don’t
worry this is normal.
30. NON CPU side.
31. After 10 to 15 seconds move onto the next area.
32. Once all marked areas have been heated/reflowed
minutes to cool.
33. A popping noise may be heard during cooling don’t
Heat sink compound still on in this picture, remove
before reflowing.
Heat sink rubber pads still on in this picture remove
before reflowing also hold ribbons out of way while reflowing;
You have just repaired you’re yloded ps3
mother board.
34. Now its time to apply new heat sink compound to
the 2 processors, when doing this its always best to
follow the manufacturers instructions but I believe the
process is the same with all types (please check
instructions that come with paste), before continuing
35. Now Get your Artic Silver 5
36. Place a Small amount of compound from top to bottom on the left hand side of
processor chip, now using a finger with some Plastic over the tip spread the
compound evenly and thinly over processor face (to much
is bad and not enough is also bad) the ideal amount is
when you can almost see through the paste.
37. Now repeat on the other processor.
38. NOW IT IS TIME TO REASEMBLE THE PS3.
RETRACE YOUR STEP IN REVERSE TO REBUILD
MAKING SURE ALL RIBBON CABLES HAVE BEEN
FULLY INSTERTED INTO CONNECTORS AND LOCKED
DOWN IN. (TABS).
on Dec 15, 2009 | Video Game Consoles & Games
Can I get the directions on the disc replacement
It really simple. First, you need the replacement disc. I have one extra that I purchased on ebay. You will need I screw driver called torx to remove stews on rear of unit. Once you remove cover, remove fans from heat sink (fined structure.) Now, locate wire connector on mother board for heat sink and disconnect. With a phillips screwdriver, remove four screws holding sink to unit. Remove heat sink being careful to route wires and connector out of passage way in cabinet. Use your camera phone to take pictures of the unit each step of the way in case you forget how to reassemble. Next, remove the four screws from the smaller square heat sink that was facing inward in unit (cooling side.) These screws may have sealant covering the phillips heads. Separate the two heat sinks and you will see the cooling disc saneiched between. You will have to cut the wires on the old disc to save the white connector to the mother board. Cut, splice, and solder the new disceires to the connector you saved. Replace everything and that's it. Mine works great.
Dec 04, 2011 | Cuisinart CWC-1200 Wine Cooler
Hey man, I saw a previous post where you were the only person to help the customer out. Probably pretty easy question, but my heat sink retention bracket for the CPU broke. It is an HP pavilion 514n. ...
I'd suggest release the other side and remove the fan & heat sink. They often come as a unit. Its very common to buy a new fan and the heat sink comes with it. It really depends on what processor your using. Its getting hard to find pent 3 stuff but otherwise you should be able to find another heat sink or fan, or combo with both and the bracket to fasten it is part of the heatsink fan assembly. Take the whole assembly to your local computer geek shop. They'll have another one.OR have a bones system they'll borrow from. You should find it on-line somewhere, but it would take awhile to find one. If you can carry in to a shop you'll be more likely to leave with the right thing. You might be able to rig it with something, but with the much heat around it and voltage being so close it wouldnt be a very good choice. I had one that broke one and then a little piece started rubbing the fan and making noise. I think the heat is what made the plastic so brittle and why it just broke.
Jan 21, 2011 | Computers & Internet
Power will only stay 0n for a few sec and then shuts off
Hi,the problem with your ps3 is a heat sync failure,it's a common problem with the ps3,however,here is a detailed solution to help you out;
You have to disassemble the ps3 first, (hint) there is a srew were your rubber boot is on the bottom were it stands up remove this srew but you my have to get a star bit with a hole in the center of it. 2. After removing the cover then sides to the screw,lift the cover to remove all visible screws in the second cover.
3. Lift the second cover in a hinged motion to the front of the ps3 be careful not to pull the hidden carbon wire underneath of the cover if done properly you will see the wire when you lift the cover. To release the wire you must lift gently on the black clip holding it and it will release with no problem.
4. You then lift the blue ray drive up and then dissconnect the wires to it. then remove the power pack which is to the left of the blue ray drive remember there are screws holding this down, remove the wires then remove this peice as well, then remove any remaining screws on the mother board cover except the large philip head screws holding the clips that are in a slant. lift the mother board out to reveil the fan on the bottom now remove the srews that are slanted. the fan will then seperat from the mother board. then clean both of the contacts on the mother board and fan with rubbing alcohol. then seperate the metal from the mother board.
attention; there will be a watch battery connected to the metal,disconnect from the mother board. gently lift up on the metal to seperate the mother board from the metal. At this point you must be extra careful not to move any of the parts on the mother board remove the rubber peices then cover the heat syncs so they dont melt use a heat gun that can reach a temp. of 350 degrees Cel heat for 15 sec on the three heat sinks with a distance of 1 inch or greater move the heat gun counter clockwise on the sensors. during this time the peice must be level or it will hurt the system. After heated you will then need to let cool for 15 min. then flip the board over and hit the exact same spots in the same steps. at this point your problem is solved. Make sure all the peices of rubber that was on the chips is put back in the right spots too.You then put the metal back on the systems mother board at this point clean the syncs again then apply the artic silver in a thin bead on two heat syncs note not too much and not to little just enough to cover the syncs with a thin coat then connect to the fan. reconnect the fan then put the screws back in that holds them together then reattach the power supply but dont srew it down then remove the srews on the fan moter then remove it plug in your system switch it on stand by then press the sensor pad metal to start the system note this will not hurt your system this causes the artic silver to soder the heat syncs together only do this till you see a orange light come from the board near the fan then shut the system down then reattach the fan and reassemble.
Take care
Jun 19, 2010 | Sony Playstation 3 (PS3) Console
Flickering image and green hue on Optoma HD200x
this happens to my hd20 sometimes. just happened on pc through hd20. when i turned it on said 30hz instead of 60hz. so i changed resolution down then back up to 1920x1080 and it is sorted.
irving6000
Apr 09, 2010 | Optoma HD20 DLP Projector
3 of 4 rings were red, now no lights at all
ok the three red rings was lit to notify you that your board, cpu and gpu have experienced a significant source of heat. So much in fact you really should bring it to a repair shop. I see these at least 4-5 times a day your 360 needs to be disassembled and the heat sinks removed this will allow you access to the cpu and gpu both sides of the board need to be heated with a equal amount of heat to heat up the solder and reseat both chips.
Mar 29, 2010 | Microsoft Xbox 360 Console
How do i replace fan acer 5739g
1.first remove battery and adopter.remove back side covers,wireless lan antenna
2. remove all the screws in bottom side.
3.just above the keboard ,the front panel neds to removed with little preasure from fingers and remove the flat cable jently. remove lcd panel cable,pull out wlan cable in upword direction.
4.un-screw screws over keyboard and lift the keyboard,look at the bottom remove the flat cable(the brown colored lock should be pushed up jently.
5.remove the touch-pad flat cable similarly & remove
any other cables
6.jently pull the top panel towards you with fingers( observr any cables/wires conected to mother board)
7.once front panel is removed remove other cables /wires connected to usb/phone socket/wlan.
8.un-screw the screws with arrow indicater to remove mother board from back panel.
9. remove the screws form heat sink attached fan jently.
replace the fan or heat sink with fan of the same part number.( a.  put few drops of any oil betwen gap pan blade and plastic it might clear dust    b. in case fan is smooth then 5 volts wont be comming from mother board(red wire) then u requir proffesional help ).
10. follow the reverse procedure to assemble the laptop.
*****before you start any work ground ur body start with bare foot as all devices are esd sensitive. try with your own risk iam not responsible for consiquential
damage to device/person .these are just hints to help*****
Mar 11, 2010 | Computers & Internet
How to remove the cooling fan
They are usually mounted on with plastic clips, sometimes with screws. Use a small screw driver to loosen the clips on all the sides at the same time so the fan can some off.
Feb 27, 2010 | Intel Socket 775 Heat Sink and Fan up to...
How can i put a keyboard in my laptop?
the piece of plastic above the key board is held in by clips,,it will unsnap..be very gental or it will break..after the top plastic is off youll see 3 screws holding the key board down,,there usally very small phillips head screws..then after the screws are out gentally lift the top of ther keyboard up..under that there will be a plastic wire strip..it will in clip at the mother board end..dont break the clip..and there is proolly 2 or 3 wires that go to your touch pad mouse...tehn just lift the key board out and follow these directions in reverse order to install the new one..
Nov 10, 2009 | Compaq Presario CQ50-215NR Notebook
Computers & Internet Logo
519 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
