Question about Optics
Replace battery in a BEC SP-5 scope
Cant figure out how to open
2 Suggested Answers
  • 75 Answers
SOURCE: Cant find out where to chang the batteries
Go to Barskas service/help desk, their Email; service@barska.com , they are in California and are quite helpful.
Good luck. :)
Posted on Apr 28, 2009
Does it matter if i use a 5 or 5.5AH replacement battery with my F6C900-UNV
you should only use the previous battery model or power of your ups bec..
it helps to work it for long time
Jan 31, 2012 | Belkin (f6c900-unv) UPS System
Cant see anything through the view finder
1. During the day, use the 17mm eyepiece on a object outside (telephone pole, water tower, etc) then align the finder to what you see in the scope.
2. Put in the 7.5mm eyepiece and fine align the red dot finder.
3. At night, point the finder at the moon (less than half moon or the image is too bright without a moon filter) Use the 17mm eyepiece.
4. Once you see the moon, switch to the 7.5mm lens and enjoy.
5. Download Stellarium or any free astronomy software and see what is in your sky tonight. Your scope should be able to see Jupiter and its moons easily.(Saturn, Mars and Venus when the time is right) Open clusters like Pleiades will be nice is this fast scope.
5. If stars are not sharp, you may need to collimate the scope. Look online for general instructions.
Nov 14, 2011 | Optics
Am having a problem with my music player. it give me this notification (unable to rebuild data base and access music player) and also can not open my files incon in menu it give this notification (not...
Goodday! the files of your music player are corrupt...or not compatible to your phone....not allowed.. bec. there is a problem in your phone. your memory cannot open bec. but after a while you will open it...why? bec. your memory is near for replacement or getting damage. try to connect to your computer input and then configure it and repair it there.
Feb 13, 2011 | Samsung GTB5702 Cell Phone
I have a Millett RD00906 that has a short in battery compartment. Ican tap on battery cap and get a dot for a moment and then loose it again. When I get the dot it is not in the normal view but usually...
The problem may be the same as I experienced with two Millett scopes:
I have had two Millett (made by Bushnell) scopes fail to "light-up" -- the usual symptom is that you turn on (or try to) the "light" (actually, a laser diode) and nothing happens or it goes on but goes off again when you shoot or bump the gun for any reason. I discovered the reason: There is a ring under the battery screw-cap that gets loose.
To repair:
  1. Take off the battery and remove the battery.
  2. You will find a ring that surrounds the battery that is loose.
  3. Remove that ring by unscrewing it the rest of the way -- this is so that you can apply a drop of blue Loctite.
  4. Screw that ring back in -- if you use Loctite, you won't have to really tighten it. If you choose not to use Loctite, it probably will loosen again no matter how tight you get it. To really tighten, you need a spanner wrench with pins (one scope) or thin blades (the other scope). I used a small Allen wrench and small screwdriver, respectively, in lieu of a spanner wrench.
  5. 5. Replace battery and cover. The Loctite needs at least 10 minutes to set before firing; 24 hours for a full cure.
Obviously, it you are at the range, simply retighten the ring so you can continue shooting and do the Loctite when you have more time.
Sep 05, 2010 | Millett Sp-2 Red Dot 30Mm 5Min Matte
No red dot
To repair:
Aug 28, 2009 | Millett Sp-2 Red Dot 30Mm 5Min Matte
Good luck. :)
Apr 18, 2009 | Barska Optics Barska® 50 mm Red Dot Scope...
How can i open my cellphone?
go to a cellphone shop and ask them to open line your phone so u would be able to use other sim card
Apr 01, 2009 | Nokia 1110i Cellular Phone
Replacing a cracked lcd screen on a GBA sp ags 001
How comfortable are you with opening you GBA? This website below is a site that I found to purchase a new screen. All you need to do now is to figure out how to open and remove the old screen. The rest should be a snap.
http://store.videogamecentral.com/gbareplscreen.html
Feb 25, 2009 | Nintendo Game Boy Advance SP GBA Red...
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
