Question about JVC XL-M509TN 7-Disc CD Changer
Cd tray won't open; won't play cd or turn off
Cds stuck inside jvc xl-m509. trays won'r open; cd won't play. can't turn off w/o difficulty
No solution - plastic thread driving opening/closing had snapped after 16 years!
Posted on May 18, 2009
JVC XL MV303 karaoke player HOW TO OPEN STUCK TRAY
on the front theres a small pin hole push gently a paper clip into there it should open
May 23, 2014 | JVC XL-MV303 CD Player
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
When I insert cd, in either 1, 2 or 3 slot and then it says no disc and opens...
Hello
Your JVC CD player has some mechanical trouble. It does not load CDs fully into the tray. Either tray loading motor or its belt iis faulty. Replace the belt first and see it helps you. If not replace the loading motro. For both, you have to open and disassemble your CD player. If you are able to do it, and have confidence, proceed. OK
Happy New Year.
Dec 31, 2010 | JVC XL-MV303 CD Player
It doesnt open and cant read the cds inside.
Remove the cover lid and look inside for anything jamming disk tray, problem may be very simple once you look at this. change out some of the cds.
Apr 09, 2010 | JVC XL-F254BK 5-Disc CD Changer
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Sonycmthpx9
if under warranty, send for repair.
No warranty, open it yourself and try to open the cd tray/door. remove anything stuck between the tray/door or wriggle the tray/door.
Aug 23, 2008 | Sony Audio Players & Recorders
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Cd changer won't open
try to open by hand,see if the tray is stuck.
opening by hand is you turn the motor.
if you put a power supply direct to the motor the pcb will be burnt
(giving a bigger problem).
Look for mechanical problems.
Mar 09, 2008 | Audio Players & Recorders
Cd Changer will not play CD's
hi does it then say no cds? does it try and load the tray? sounds like it is not reconising that any cds are inserted, could be the laser, faulty or the tray is not reaching the tray in/loaded switch. not worked on many jvc units, so it a bit of guess work regards Mark www.carradiospares.co.uk
Jan 08, 2007 | JVC CH-X470RF 12-Disc CD Changer
Tray error
I saw on another JVC systems manual that its an error message that shows when the tray isn't fully open due to an obstruction. If you can locate a manual eject button(usualy you'll need to insert some tip into it) it will help you eject the tray and look for any obstructions, anything looking out of the ordinary there. at least that way you'll be able to take your cds out... You can also try disconnecting the system from all power sources for a few days(including an internal battery), maybe the reset will jog it back to working order. If you're out of warranty and know your way around those things, try taking it apart, cleaning as much as you can, and look for anything out of the ordinary, like broken gears or pins, bent parts, a cog, etc. Good luck
Feb 12, 2006 | JVC FS-S77 System
682 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
