Question about Honeywell Heating & Cooling
Compressor relay switch
Have a Honeywell Pro 6000 thermostat with a Aquaterm AC60 water heat pump unit connected. Recently the compressor of the heat pump sometime stays running after the heating should stop (set temp reached or thermostat on off). However, only the fan fan switches off. It seems to me that the one relay that controls the compressor is not switching off. Usually there's are two relay click sounds when the heat switches on or off, one for the fan, one for the compressor). Has anyone had similar problems or can confirm that it might be a relay problem of the thermostat? Thanks.
    Scholar:
  • 45 Answers
What temperature is this heat pump being run at? If it is low ambient temp outside this may be running in what is called defrost mode to where the compressor will run without a call for heat. This seems normal to me as long as the setpoint temperature is being reached.
Posted on Jan 01, 2014
3 Suggested Answers
mikadot
  • 2113 Answers
SOURCE: i have a honeywell thermostat t6360.the light
Many thermostats have battery backup as well as the 24 volt ac. Have you replaced the batteries to see if it fixes all of your issues at once?
Posted on Nov 02, 2013
SOURCE: honeywell heating/AC thermostat intermittently going blank yet heat seems to be running okay. What could be the problem?
All you can do is check the battery's and their connection in their base. I have seen this before and ended up replacing the stat. Wait a little while before replacing it. Maybe one of the other guys knows of something I don't. I hope so. Good luck.
Posted on Dec 18, 2013
Why does my American Standard heat pump compressor and condenser fan run when I have the thermostat set to emergency heat?
It's possible the "brain" thinks it can still supply some heat. Other wise there is a wiring problem or thermostat switch problem. Installed recently? Never used emergency heat before? What is your emergency heat type, gas or electric? Are you sure they are working. If not the "brain" senses and uses the only source available: heat pump. Thermostat? probably Honeywell? If so call Mfg customer service. Warranty on thermostat or heat pump? If so call customer service. Call your installer.
Feb 28, 2015 | American Standard Heating & Cooling
How to troubleshoot thermostat wiring?
I'm not sure if the thermostat is wired correctly. First, the thermostat is wired directly to the outdoor unit (compressor/condenser unit). It is NOT directly connected to the indoor unit. It connects to a low voltage control panel in the outdoor unit that sends a signal to your indoor fan/evaporator. This wire is called the fan relay switch and physically runs between the low voltage controls of the indoor and outdoor units. If the fan relay is bad it's possible that the unit runs continuously. To prevent destroying your outdoor unit there is a safety feature that prevents the indoor fan from shutting down while the outdoor unit is running. If the indoor fan did shut down while the outdoor unit was running than you would slug your compressor. That is, your compressor normally sees refrigerant gas but is instead seeing refrigerant liquid. That would not be good since this scenario would destroy your compressor. It sounds like a faulty fan relay. The actual contactor portion of the relay is in the outdoor unit.
Aug 22, 2014 | Honeywell Electronic Programmable...
Honeywell focus pro 6000 thermostat
Right below the w setting on the base plate is the o/b connection. Put the O wire in this slot. During the initial test for heat and cool, the bias for cool for function 2 is 0 and for heat it is 1. To reach the programming press fan and Up arrow. Press next to reach function 2. Be aware the the O wire is energized and operates the reversing valve. Some manufacturers energizes the reversing valve to go into cooling, and some leave it deenergized to be in cooling. Select either 0 or 1 to make the system perform in the correct mode.
Hope this helps.
Jul 25, 2014 | Honeywell Focus Pro 6000 Programmable...
Heater problem
Is the unit a heat pump? If so then check the aux heat relay to see if the electric heat strips come on.
Feb 05, 2014 | Honeywell PRO 4000 5-2 Day Programmable...
Honeywell RTH2310 heating while it's supposed to be cooling
ok to start with if you have a heat pump and not ac over electric heat depending on type but most will be wired as
red to r jumped to rc y to yellow this turns on compressor g to green this turns on fan w to white or brown for electric heat strip or em heat o to orange reversing valve energised in cooling switches from heat to cool or orange to b energised in heating c blue for common
you will have to look at your indoor unit and out door unit to verify what collors the contractor used when they wired it up hope this helps
May 31, 2009 | Honeywell Programmable Thermostat Heater
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat
Make sure G from indoor unit goes to G on thermostat for fan continous fan, if that doesn't work and you have 24 volts to R and C then the t'stat is bad.
For 2nd stage heat or aux.heat, on the indoor unit you need to make sure the wire W2 from the indoor unit goes to W2 on t'stat.
You don't need any wires from W1on the indoor unit to W1 at the t'stat because with a York heat pump Y1 is the contactor which turns the compressor on and you will get 1st stage heat, and for cooling the t'stat will also bring on O which is the (reversing valve) or cooling changeover relay for the cooling mode.
C = common usually black wire
R = hot usually red wire
Y or Y1 = contactor
W1 = 1st stage heat not needed for heat pump
W2 = Aux. heat indoor heat
G = fan
O = Cooling changeover relay
B = Heating changeover relay
L = System monitor
E = Emergency heat relay
Dec 23, 2008 | Honeywell Electronic Programmable...
Lost directions to program a thermostat
i have a pro 6000 t stat it shorts cycles any clues to change the off set
Nov 09, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
99 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
