Question about Fellowes PS60C-2 Shredder
Staples 12 sheet shredder stopped running power light on when forward pressed nothing happens but reverse indicator blinks
SOURCE: p400c-2 fellowes shredder only runs in reverse no
I just had the same problem. I called the 800 # they asked for proof of purchase to replace if 1 year old. I did not have it so...... I took it apart ------ unpluged ! Only to find all gears are fine, service dept. said gears cause this problem, not so with mine. Remove top by pulling of base remove 6 screws on under side, played with the switch inside a bit and, it now works, do not know how long but for know it does. My opinion is the relay gets dirty, and you cannot clean it without talking whole thing apart.
Posted on Apr 21, 2009
FixinFax
  • 3085 Answers
SOURCE: Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Posted on Jul 05, 2009
SOURCE: shredder motor will run in reverse, but not
The switch referred to above is the optical reader. I turned the machine off , and used windex to clean the optical reader area. It works...
Posted on Nov 25, 2009
squipps
  • 204 Answers
SOURCE: our fellowes shredder runs in reverse
Sounds like the rocker switch is turned around. I would just change it or re lable the switch
Posted on Dec 18, 2009
bbl242003
  • 1637 Answers
SOURCE: The shredder motor will run in reverse only. When
Welcome to fixya
I have a solution for this, Please follow up with me if you need more information. Content
There is paper stuck inside the shred blades, unplug your unit and remove the paper. You will find that your shredder works in normal direction again. IE SHREDDER EXPERT
More information is available in the comments
My name is Bruce
Posted on Jan 21, 2011
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
http://www.snoopdeal.com/bargain/43085/Staples-SPL-TXC6A
Nov 21, 2016 | Office Equipment & Supplies
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
How do you fix the Shredstar PS817c that is stuck in reverse?
If you want to try to resolve the problem yourself I suggest you use their Customer Service to help answer your question: Online Service Portal HSM of America
http://www.hsm.us/service/online-service-portal/
Jul 11, 2014 | HSM 1030 shredstar PS817C Medium-Duty...
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Omnitech only runs in reverse
In the middle of feed opening there is a sensor which in your case will be stuck. Try clear it using tweezers. Failing that soak the blockage up excessively with WD-40 as it will loosen and soften stuck paper leave it for 10-15 minutes, repeat 2-3 times. Then power on the unit and it should be good as new! Good luck
Jul 19, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
Jul 05, 2009 | Fellowes 3011001 Shredder
Aurora AS1512X Cross Cut Shredder
Sounds like the cutter is jammed. Do you ever feed staples or clips in it? Will it reverse? If not, the power borad is burned out.
Jul 24, 2007 | Cross Aurora 15 Sheet Cut Shredder -...
Fellowes PS60C-2 Shredder Logo
42 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
