Question about Samsung Televison & Video
How to fix my Samsung un60es8000
The tv turned off by itself
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
Why screen has now black horizontal lightings on white images each side?
load the pics.
for example check the Vertical lines on Samsung LED TV
it's not a permanent fix, and if you want to fix it completely then disconnect all the cables to the main board(AV board), clean the contacts then put them back as they were. Secondly, look around all the connectors in that area where you loosened the screws
Mar 23, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Jan 05, 2016 | Televison & Video
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
? 4:41
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
60 inch samsung led tv turns off and on while watching
it may caused by the dust.
open up the led tv and clean it using the blower.
Jul 29, 2015 | Samsung UN60ES8000 60 inch 240hz 3D Slim...
Samsung led TV un60es8000 dark blotchy area on the upper right of screen. Most noticeable on greys,blues and blacks. The picture attached is the color most responsive to this issue (dark grey). Lighter...
This is caused by one of two things; a bad LED grouping (most common cause) either because the LEDs are bad or the power distributor fuse is blown and the group isn't getting power from the power supply unit. Or two: bad pixel group. But I'd check your backlight power supply for bad connections, blown fuses, or check your led groups for bad leds.
Jan 28, 2015 | Samsung Televison & Video
Got sound but no picture on samsung tv model code PN60E530. Help?
Use a flashlight up against the screen to check for picture, if you have a picture, then the inverter is bad.
Jul 12, 2014 | Samsung UN60ES8000 60" 1080p LED 3D TV...
Samsung UN60ES8000 internal speakers don't work
The speakers may have been turned off at the time of initial setup, especially if you planned to use external audio
Mar 17, 2013 | Samsung UN60ES8000 60" 1080p LED 3D TV...
Samsung dlp hdtv turns itself off
Have a 46 inch behaving the same way. I have the extended service contract, so they are getting a calll tomorrow. I ll post what they say
Dec 27, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
163 people viewed this question
Jerry Greenberg
Jerry Greenberg
