Question about Bunn My Cafe MCU Brewer
Won't pull water into main tank on initial set up
How does pressure tanks work
Pressure tanks do just that in a water system. They create pressure for water to flow when the water pump is on the off cycle. A manifold is plumbed into the tank from the main line coming from the well. The main water line continues to the house plumbing from the manifold. So it's line from pump to manifold - to tank, and from manifold to main into house. The manifold also has tappings for the pressure gauge and the pressure switch. The pressure tank creates water pressure. The water does not flow through the tank. Pressure tanks also have to be 'tuned' or adjusted to the low end pressure set by the pressure switch. Actually the tank pressure needs to be set 2psi below the low end pressure. Most residential water systems are set to operate between 20 -40, or 30-50 psi, which is set by the pressure switch, which in turn , turns the water pump on and off. So if a system operates between 20 and 40 psi, the pre-charged pressure of the tank should be 18 psi. Pre-charged means the tank is drained of water with the water pump OFF. The tank pressure is then checked adjusted by way of the air valve on top of the tank ( A tire gauge works). Pressure tank mainfolds are a common plumbing part.
Mar 19, 2014 | Utilitech 20-Gallon Vertical Pressure Tank...
Clog won't pull water
Type information in to your post. Not just a video. I am VicFixx, not VicPsychic. The more information the better.For the info you gave.
Fill tank with a 20% solution of vinegar and water.
Try to brew a large cup or two.
Turn off machine and let sit over night.
Use a wetvac (Not a regular vacuum. You can electrocute yourself.) and use some duct tape across the wetvac nozzle to make the end smaller. (About the size of a quarter.)
Remove the tank, turn on the wetvac and use it to **** the clog out of the inlet the tank plugs into.
If all goes well it should remove the clog.
Feb 23, 2013 | Coffee Makers & Espresso Machines
My bissell proheat 2 x won't spray water
PLEASE GO TO THE PAGE FOR TROUBLESHOOTING AND HELP
http://www.bissell.com/how-to-videos/
God bless you
Jul 23, 2012 | Bissell Vacuums
My bissell proheat 2 x won't spray water or vacuum water
please go to the web pages videos for troubleshooting and help:
God bless you
Jul 23, 2012 | Vacuums
The unit has not been used for some time. How does one get to 70 degree C of the water in the tank? What is the proper procedure to follow to initialize the heater?
If it hasn't been used for a long time and it's still connected, turn off the cold water and drain the tank. Then turn the cold water back on and fill the tank, make sure you turn on a hot water spigot that's furthest away from the tank until the air sputtering quits then turn it off.
Light the pilot and set the dial for the temp. you want. Don't set it so high that an older person (like me) or a child can burn themselves.
Jan 05, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Just bought B40 unit and in the initial set up there is no flashing blue light, just a blue light. Is this unit a lemon?
flashing blue lite means tank is out, or needs water..if you have water in tank re-seat the tank
Dec 19, 2010 | Keurig B60 Coffee Maker
Mine sucks because it DOESN'T ****.
First check that the dial on the side of your steamer is set to carpet for carpet and tools for tools, I know this is simple.
Now make sure that the water tank is down properly. Sometimes the little rubber seals on the bottom of the water take pulls off and gets stuck in the base of the machine. Make sure you have the rubber seals on the bottom of the tank before you put the water tank onto the machine.
Aug 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Start Thermostat
This machine has only main control board and beyond the basic settings is not possible to make any changes. Perhaps it was there to reset previously set water temperature in the tank.
Jan 20, 2008 | Fetco International CBS-2018 Coffee Maker
Bunn My Cafe MCU Brewer Logo
243 people viewed this question
Top Bunn Electronics - Others Experts
Are you a Bunn Electronics - Other Expert? Answer questions, earn points and help others
