Question about Amana AGDS902 Gas Kitchen Range
Amana AGR5630BDW oven randomly shuts itself off while in use
P5H code on an amana oven
This is actually the 'PSH' error code which stands for 'Push To Start'. If you do not press the start button within five seconds of a command that will display telling you, that you forgot to PUSH the Start button. If it is randomly showing up by itself you have a defective touch-pad
Oct 21, 2016 | Amana Kitchen Ranges
What does p5h code on an amana oven
I have an amana acs 3350 that keeps shutting off when it gets hot. The tips i research tell me that either the fan is dead or the door is not shutting correctly. The fan would cool down the control board?...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 30, 2011 | Amana ACS3350AS Gas Kitchen Range
I have a Panasonic NN-SD277S Microwave Oven Initially, it shut itself off after about 3 secs - this continued time after time - then I held the start button down and it shut down completely, almost as if...
I have an Amana Radar range and it did things similar to that. I finally figured it was the circuit board of the buttons and was lucky enough to find another one and replace it..
Jan 26, 2018 | Microwave Ovens
My gas oven keeps shutting off during cooking amana apartment size free standing gas oven
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 18, 2011 | Amana Ovens
Aman biult in oven
F2 is Oven sensor is out of range .. oven sensor is sending a reading that the control can not understand... replace oven sensor and you may have to replace the control too as it may not be reading correctly... good luck and let me know if it helps
Jan 02, 2008 | Amana AOCS3040 Electric Single Oven
Amana AGDS902 Gas Kitchen Range Logo
16 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
