Question about Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN (MHV2080BH) 80 GB Hard Drive
Diagram st380817as I need a diagram of HDD. One lever has come out. I want to fix it
    Problem Solver:
  • 13 Answers
If you mean a pin for the IDE connection you should be able to solder one back into the same place, you shouldn't need a diagram, also circuit diagrams would be very hard to come by.
Posted on Dec 30, 2013
Wiring diagram from harness to indicator lever
Sorry, I have been in the auto repair business for 37 years and I have no clue what an "indicator lever" is. Are you talking about a gearshift indicator? a turn signal lever? Please clarify what it is you are trying to fix.
Apr 21, 2012 | 1984 Toyota Land Cruiser
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
My Hdd Has Been Not Ditected
Sounds like your drive needs to be formatted, click the start icon in your taskbar then right click "computer" and select "manage" this will open the "computer managment" window from the list select "disk managment" and your drive should be visible in the lower list on the right. Right click and select format from the list. Hope this helps
Aug 26, 2010 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
How to find my hdd warranty??
If you want to know the warranty of your hdd then click the below link and fill the details and check your warranty
http://support.seagate.com/customer/warranty_validation.jsp?form=0
How To Find Model and Serial Numbers
If your drive is connected to your computer: Seagate has created a very simple tool that will tell you the serial number and the model number of any and all Seagate and Maxtor-brand drives connected in or to your computer. Use the DriveDetect.exe method to find both numbers.
You can also use SeaTools to display each number.
(See below if you have a Mac computer.)
If your drive is not connected to your computer: See the flash-based Serial Number locator tool to find your serial number and model number (and/or occasionally the serial number and the part number) on the drive label.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 01, 2010 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
HDD PROBLEM
HI,
The first thing is to do a disk cleanup.Go to START>PRROGRAMS>ACESORIES>SYSTEM TOOLS>DISK CLEANUP. Make sure you also clean all the system restore files.If you've taken a backup of your PC and you want to keep it then just ignore that part or else just go to the more options tab and select clean up under the system restore option in the disk cleanup.
If this doesnot fix the problem then:
there is a temporary file somewhere inside in the c-drive which is growing and eating up all your space. CLICK HERE to download the jam software.The run a scan with it it will tell which file is taking more space.Then just brows that file and delete it.
Goodluck..
May 08, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Trouble in HDD
I dont think its supposed to copy data in a boot process
copying and booting are totally different processes
Did you mean to say you have hdd issues
Feb 28, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
Feb 04, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Bad sectors and fails under minor load
No it's not repairable. Copy any data you want from it to another drive, cd, dvd, etc. Go to www.seagate.com and fill out a warranty RMA form. If it's warranty you'll get a new one from Seagate
Jan 06, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN (MHV2080BH) 80 GB Hard Drive Logo
116 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
