Question about Cajun Injector 01939 Electric Smoker
I just received a Cajun Injector Electric smoker for a Christman gift and it is turning off and on rapidly after about 3 hours into the first use. Is this normal operation?
"Just licking on and off and temp setting seems to be all over the place although timer is functioning properly.
I need part for Cajun Injector smoker
What's the model number and what's the part you need? If you're not sure what the part's called, check here:
https://www.manualslib.com/manual/733139/Cajun-Injector-Electric-Smoker.html?page=4
Feb 28, 2018 | Cajun Grilling
I have a double glass door cajun injector electric smoker. I need to replace the heating element located under wood chip pan.
online search using make and model or if have the owners manual call their customer service number
Nov 13, 2017 | Cajun Grilling
Where can i buy replacement elements for the cajun injector smoker
Sorry we do not have parts locator services here.
Sep 04, 2017 | Cajun Grilling
Why wont it heat up
sounds like a bad thermostat check the probe wiring and make sure theyre not touching then check to see if they are grounding out anywhere (touching metal with a bare wire) if thats not the problem replace the thermostat
Mar 30, 2016 | Cajun Injector 01939 Electric Smoker
Cajun injector electric smoker stopped working
Check for power at your outlet; a tripped GFI or a tripped breaker in your panel box may be the cause if the outlet is dead. If the outlet is good then you know it is the electric smoker.
Nov 27, 2014 | Cajun Injector Double-Door Xl Electric...
Thermostat is stuck on 387 degrees. How can I fix it?
I had the same problem. Readout showed 330 degrees, but it should have been 60. Saw all the bad reviews on this product after I started to research this problem, so I figured I would try to fix it. I drilled all the rivots out of the back panel. There are 2 thermocouples, 1 for the meat probe and 1 for measuring the temp inside the smoker. Both thermocouples have connectors in about the center of the smoker. I cut the wire on both sides of this thermocouple and spliced them together without the connector. Works fine now.
Jan 11, 2014 | Cajun Injector 01939 Electric Smoker
Electric smoker won't heat up
yeah you could retro fit it and hope for the best..just dont leave it unattended in use..
Jan 11, 2014 | Bruce Foods Cajun Injector Creole Garlic...
I need a replacement heating element for a Cajun injector electric smoker
Hi, replacing heating elements can be found at amazon, click here and take a look: Save Time Money and Energy with Induction Cooking. I hope this helped you. Have a nice day
Oct 21, 2010 | Bruce Foods Cajun Injector Creole Garlic...
Cajun Injector 01939 Electric Smoker Logo
64 people viewed this question
Top Cajun Injector Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Cajun Injector Grilling Expert? Answer questions, earn points and help others
