Question about Hardware & Accessories
How do I enter a program to be on at 7:00 pm and of at 11:00 pm
  • 5,089 Answers
How to set date and time onxe-a102 cash register
turn key to PGM then
for Date enter MMDDYYYY press CA button (example) 09282012
for time enter hhmm press CA button (example) time must be in military time increments for example 11:00PM will be entered as shown (2300).2300 hours will showupon your receipt as 11:00 PM. If you have any problems with SHARP equipment call 1-800-BE-SHARP.
Sep 27, 2012 | Sharp XE-A102 Cash Register
Tip
Avaya Partner Phone System Programming
Programming Without Button Overlays: <br />Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.<br /><br />Avaya Partner System Date Program #101<br /> <br />Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.<br /><br />Considerations: <br />The System Date date-stamps the back up files when you use Backup Programming.<br /><br />Programming Without Button Overlays:<br />The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.<br /><br />Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Day Program #102<br />Use this program to set the day of the week that appears on system display telephones.<br />Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:<br />1=Sunday<br />2=Monday<br />3=Tuesday<br />4=Wednesday<br />5=Thursday<br />6=Friday<br />Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Time Program #103<br /> <br />Considerations: <br />Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.<br /><br />Programming: <br />To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
on May 27, 2011 | Lands Phones
I have a White-Rodgers programmable thermostat. I have it set to go to 74 degrees at 11:00 PM. It has started going to 74 at between 10:00 and 10:30 PM. If I press run it goes back to the daytime temp...
Hello I assume its cooling program.Probally the thermostat has a recovery mode.In another words the thermostat will come on EARLY to make sure you are at (74*f at 11:00).Maybe try 11:30 start time and see if that helps or disable energy recovery mode.
Jun 17, 2011 | Heating & Cooling
Need to change the time
Avaya Partner System Time Program #103 Considerations: Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.
Programming: To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
May 27, 2011 | Lucent PARTNER18 Corded Phone
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
I need to change the time on my clock - Panasonic KX-T7730
There are a few types of phone sytems that work with the kxt 7731. these instructions should handle most of them.
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set.
1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000
4.- Press "SPEAKER" button
5.- Press "FORWARD/DND" button to change to the hour selection
6.- Press "TRANSFER" button and enter the hour
7.- Press "FORWARD/DND" button to change to the minutes parameter
8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter
10 Press "MUTE" button to select AM or PM
11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed)
12.- Press "HOLD" button
13.- Press the "PROGRAM" button on the face of the phone
Nov 02, 2009 | Panasonic KX-T7730 Corded Phone
Simplify the changing of the timeon the Panasonic phone KX-T7731
Changing the time on a Panasonic KX-TA624 system must be done from extension # 101 using a display phone. All others can use any display set. 1.- Press the "PROGRAM" button on the face of the phone
2.- Enter programming2.gif mode by pressing "STAR" - "POUND" - "1234" (default password = 1234)
3.- Enter program # 000 4.- Press "SPEAKER" button 5.- Press "FORWARD/DND" button to change to the hour selection 6.- Press "TRANSFER" button and enter the hour 7.- Press "FORWARD/DND" button to change to the minutes parameter 8.- Press "TRANSFER" button and enter the minutes 9.- Press "FORWARD/DND" button to change to the AM/PM parameter 10 Press "MUTE" button to select AM or PM 11.- Press "STORE" button (listen for 1 tone if procedure was executed correctly / 3 tones if procedure failed) 12.- Press "HOLD" button 13.- Press the "PROGRAM" button on the face of the phone
Nov 02, 2009 | Panasonic KX-T7731 Corded Phone
Changing time
After pushing 103 the phone just beeps and does not go into time
http://dstech1.com/changing-time-on-a-partner/
Partner ACS, any release
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
Nov 25, 2008 | Avaya Partner 34B Corded Phone
Hardware & Accessories Logo
60 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
