Question about rss2search.com
Rss2search How do I remove this??
2010 jeep patriot 4x4 front wheel drive do I pull the engine from the top or out the bottom would like to leave trans in car W
47steps in the factory FSM book covers that. answer yes.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the engine oil.
  3. Drain the cooling system.
  4. Properly relieve the fuel system pressure.
  5. Remove the hood.
  6. Remove the engine appearance cover.
  7. Remove the air intake assembly.
  8. Disconnect both cables from the battery.
  9. Remove the battery and battery tray.
  10. Remove the coolant reservoir.
  11. Remove the power steering reservoir.
  12. Remove the windshield washer reservoir.
  13. Remove the coolant hoses from coolant adapter.
  14. Remove the grill closure panel.
  15. Remove the upper radiator hose support.
  16. Disconnect the engine electrical connectors and reposition harness.
  17. Remove the air intake tube from throttle body.
  18. Disconnect the fuel line from fuel rail.
  19. Remove the vacuum lines from throttle body and intake manifold.
  20. Remove the wiring harness from the intake.
  21. Remove the throttle body support bracket.
  22. Disconnect the electronic throttle control and manifold flow control valve electrical connectors.
  23. Remove the PCV hose, and make-up air hose from valve cover.
  24. Remove the dipstick.
  25. Remove the intake manifold mounting bolts and remove the intake manifold. Refer to Intake Manifold, removal & installation.
  26. Disconnect the electrical connectors and reposition the harness.
  27. Remove the accessory drive belt. Refer to Accessory Drive Belts, removal & installation.
  28. Remove the power steering line support at the engine mount and exhaust manifold.
  29. Remove the power steering pump and set it aside.
  30. Remove the upper idler pulley.
  31. Remove the ground strap near the right tower.
  32. Raise and safely support the vehicle.
  33. Remove the right front wheel.
  34. Remove the engine splash shield.
  35. Remove the torque converter inspection cover and match-mark the torque converter to the flywheel.
  36. Remove the torque converter bolts.
  37. Remove the lower bell housing mounting bolts.
  38. Remove the A/C compressor mounting bolts.
  39. Remove the alternator and the lower idler pulley.
  40. Disconnect the Crankshaft Position (CKP) sensor electrical connector and remove the sensor.
  41. Remove the exhaust variable valve timing solenoid.
  42. Install an engine lift chain to cylinder head, as shown.
  43. Connect the chain to the rear engine lift hook.
  44. Install engine lifting crane.
  45. Remove the right engine mount through-bolt.
  46. Remove the engine mount adapter retaining bolts and the mount adapter.
  47. Carefully lift the engine from the engine compartment.,,,end. removal.
Nov 09, 2015 | Jeep Cars & Trucks
How change front fender f150 2000
Fender -Front Removal
  1. Remove the radiator grille opening panel reinforcement (8A284).
  1. If equipped, remove the front wheel opening moulding.
    1. Remove the pin-type retainer.
    1. Remove the screws.
    1. Remove the wheel opening moulding.
  1. Remove the front fender splash shield (16103).
    1. Remove the pin-type retainers.
    1. Remove the front fender splash shield.
  1. Remove the cowl grille.
  1. On RH front fender, remove the antenna mast.
  1. On RH front fender, remove the antenna base.
    1. Remove the radio antenna base cap (18A927) by gently inserting a thin straight-edged screwdriver underneath the cap and carefully following inside the perimeter until both snaps are free.
    1. Lift the antenna base.
    1. Disconnect the radio antenna lead-in cable (18812) and remove the antenna base.
  1. Remove the fender stuffer.
  1. Remove the stone guard.
  1. Remove the front fender.
    • Remove the bolts.
Sep 17, 2014 | 2000 Ford F150 Flareside SuperCab
How to remove oil pan
4x4
1. Open the hood.
2. Disconnect the battery negative cables.
3. Remove the intake air assembly.
4. Remove the radiator shroud retaining bolts.
5. Install engine support fixture # 8534B .
6. Raise and support the vehicle.
WARNING: HOT OIL CAN CAUSE PERSONAL INJURY.
7. Drain the engine oil (Refer to 09 - Engine/Lubrication/OIL - Standard Procedure) .
8. Loosen the front engine mount bolts.
9. Lower the vehicle.
10. Use the engine support fixture # 8534B to raise engine out of the front mounts.
11. Remove the engine oil dipstick.
12. Raise and support the vehicle.
13. Remove oil pan bolts, break the pan to block seal, and lower pan slightly and remove oil suction tube fasteners.
14. Remove oil pan and suction tube.
15. Remove the 2 bolts from the front of the engine block stiffener.
16. Remove the oil pan.
4x2
1. Open the hood.
2. Remove the negative battery cables.
3. Raise and support the vehicle.
4. Remove the transmission oil cooler lines.
5. Remove the propeller shaft.
6. Remove the starter bolts.
7. Support the starter.
8. Remove the torque converter bolts.
9. Remove the exhaust hanger bolts.
10. Remove the gear shift cable.
11. Remove the wiring harness.
12. Remove the transmission mount.
13. Remove the crossover bolts.
14. Position the transmission jack.
15. Remove the bell housing bolts.
16. Remove the transmission.
17. Remove the flywheel housing bolts (8).
18. Remove the flex plate bolts (8).
19. Remove the engine oil dip stick.
20. Drain the oil.
21. Remove the steering rack bolts.
22. Remove the oil pan bolts.
23. Remove the oil pickup bolts.
Aug 01, 2014 | Dodge Ram 3500 Cars & Trucks
How to change the heater core
Heater Core
Removal and Installation Procedure for 2001 Windstar.
Remove the cowl top vent panel. Disconnect the heater hoses.
Remove the lower instrument panel utility compartment.
Remove the ash receptacle.
Remove the rear seat airflow duct.
Remove the pins.
Remove the duct.
Remove the four instrument panel support bolts and detach the electrical connectors.
Remove the nuts and remove the center instrument panel support bracket.
Remove the bolts and remove the support brace.
Remove the 2 screws and remove the floor duct.
Remove the 7 cover screws and remove the cover.
Remove the dash panel seal.
Remove the core.
To install, reverse the removal procedure.
Nov 05, 2010 | 2001 Ford Windstar
How do you remove toyota timeing chain
Timing Chain and Gears Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain cooling system.
  3. Remove the upper front fender apron insulator.
  4. Remove the upper radiator support insulator.
  5. Remove the right front wheel and tire assembly.
  6. Remove the right lower splash shield.
  7. Remove the drive belt and alternator.
  8. Remove the air switching valve (XRS)
  9. Remove the power steering oil pressure switch connector.
  10. Remove the 2 power steering mounting nuts and through bolts. Remove the steering pump from the engine. Secure the steering pump to the cowl toy_car_15_wood_block_on_jack.gif
  11. Raise and support the engine with floor a jack. toy_car_18_eng_rh_mntng_inslt_blts.gif
  13. Remove the 2 nuts, 2 clips and the cylinder head shield (except XRS).
  14. Remove the 4 ignition coils.
  15. Remove the 2 ventilation hoses from the cylinder head valve cover.
  16. Remove the 9 bolts, 2 seal washers, 2 nuts, cylinder head cover and gasket (except XRS). XRS toy_car_18_eng_cylndr_hd_cvr_blts_2zz-g.gif
  17. Remove the 4 bolts and the cylinder head shield (XRS).
  18. Remove the 2 nuts, bolt and remove the ventilation hose from the ventilation pipe (XRS). XRS toy_car_18_eng_cylndr_hd_cvr_ventl_hs-pp.gif
  19. Remove the Ventilation pipe and gasket (XRS).
  20. Remove the 9 bolts, wire harness protector. Remove the cylinder head cover and gasket (XRS).
  21. Remove the O-ring from the cylinder head cover (XRS)
  22. Turn the crankshaft pulley and align its groove with timing mark "0" on the timing chain cover. toy_car_18_eng_tmng_mark.gif
  23. Ensure that the marks on the camshaft timing sprockets are in straight line on the timing chain cover surface as shown. toy_car_18_eng_tmng_point_marks.gif
  24. If not turn the crankshaft 1 revolution (360°) and align the marks as above.
  25. Remove the crankshaft pulley toy_car_18_eng_rmv_crnk_sft_pos_snsr_blts.gif
  26. Remove the 2 mounting bolts and remove the crankshaft position sensor.
  27. Remove the mounting bolt, nut and the drive belt tensioner.
  28. Remove the right engine mount bracket.
  29. Remove the front exhaust pipe (XRS).
  30. Remove the Exhaust manifold brace (XRS).
  31. Remove the Exhaust manifold (XRS) toy_car_18_eng_tmng_chn_tnsnr_blts.gif
  32. Remove the 2 mounting nuts and remove the chain tensioner.
  33. Remove the water pump. Except XRS toy_car_18_eng_tmng_chn_cvr_blts_1zz-fe.gif
  34. Remove the 11 mounting bolts and nut (except XRS).
  35. Remove the 12 bolts (XRS).
  36. Remove the stud bolt.
  37. Remove the timing chain cover and 2 gaskets.
  38. Remove the crank sensor plate.
  39. Remove the timing chain tensioner slipper mounting bolt. Remove the tensioner slipper. toy_car_18_eng_tmng_chn_sprkt.gif
    Note: If the crankshaft timing sprocket cannot be removed by hand, use 2 screwdrivers. Position shop rags as shown to prevent damage.
  40. Remove the timing chain and crankshaft timing sprocket.
  41. Remove the 2 chain vibration damper mounting bolts. Remove the vibration damper toy_car_18_eng_tmng_cntrl_assy.gif
  42. Hold the camshaft hexagonal section with a wrench. Remove the sprocket mounting bolt.
  43. Remove the valve timing controller assembly and timing sprocket.
Note: Be careful not to damage the cylinder head and valve lifter with the wrench.
Do not disassemble the valve timing controller assembly.
Oct 19, 2010 | 2005 Toyota Corolla
Change oil pump from engine
THE 3.0 ENGINE YOU HAVE TO REMOVE THE UPPER INTAKE MANIFOLD .REMOVE VALVE COVERS REMOVE ACESSORY DRIVE BELT.REMOVE THE POWER STEERING PUMP.REMOVE ALTERNATOR REMOVE WATER PUMP .REMOVE AC COMPRESSOR AND BRACKET .REMOVE CRANKSHAFT PULLEY REMOVE OIL PAN REMOVE OIL PUMP SCREEN AND THE TUBE REMOVE FRONT COVER REMOVE TIMING CHAINS REMOVE CRANKSHAFT TIMING GEARS REMOVE OIL PUMP.WHEN INSTALLING NEW OIL PUMP AND OIL PUMP SCREEN AND TUBE TORQUE BOTH 89 INCH POUNDS. THE 3.9 ENGINE REMOVE THE CRANKSHAFT PULLEY REMOVE FRONT COVER REMOVE THE PRIMARY TIMING CHAINS REMOVE OIL PUMP MOUNTING BOLTS REMOVE OIL PUMP.INSTALLING NEW OIL PUMP TORQUE BOLTS TO 53 INCH POUNDS. WARNING YOU NEED A REPAIR MANUAL IN ORDER TO RELINE TIMING MARKS ON CAMSHAFTS AND CRANKSHAFT.
Apr 22, 2010 | 1997 Lincoln Continental
1999 ford windstar heater
If you are trying to remove the heater core I can help you. First you shouold get the heater core pressure tested..if it doesnt leak there may be another problem. To remove follow the steps:
  1. Drain the cooling system.
  2. Remove the cowl top vent panel.
  3. Disconnect the heater hoses.
  1. Remove the lower instrument panel utility compartment.
  2. Remove the ash receptacle.
fbf69d7.gif 6.Remove the rear seat airflow duct.
>Remove the pins.
>Remove the duct.386d8f6.gif 7. Remove the four instrument panel support bolts and detach the electrical connectors. d5ba400.gif 8.Remove the nuts and remove the center instrument panel support bracket27b17f3.gif 9.Remove the bolts and remove the support brace4fd1990.gif 10.Remove the screws and remove the floor duct9eed5c5.gif 11.Remove the cover screws and remove the covera3be9b7.gif 12.Remove the dash panel sealf738054.gif 13.Remove the core.dfbbbd4.gif 14.To install, reverse the removal procedure.
    • Lbricate the coolant hoses with MERPOL® meeting Ford specification ESE-M99B144-B or plain water only, if needed.
Dec 28, 2009 | 2003 Chevrolet Silverado 1500
Fixing heater core on Mercury Villager front one
go here for lots of help
http://groups.yahoo.com/group/villagerquest/
Heater Case Removal
  1. Drain the engine coolant. Refer to Section 03-03 for the procedure.
  2. Disconnect the battery ground cable (14301).
  3. Disconnect the heater water hoses (18472) from the heater core (18476) at the bulkhead.
  4. Remove the instrument panel lower center panel (04494). Refer to Section 01-12 for the removal procedure.
  5. Remove the glove compartment and LH instrument panel lower cover (044L97). Refer to Section 01-12 for the removal procedure.
  6. Remove the instrument panel ash receptacle (04810).
  7. Remove the two upper center instrument panel finish panel screws and the two lower center instrument panel finish panel screws.
  8. Remove the center instrument panel finish panel (044D70) and disconnect the cigar lighter socket and cigar lighter illumination lamp electrical connectors.
  9. Remove the four radio chassis bracket screws and pull the radio chassis (18806) and climate control assembly from the instrument panel (04320). Disconnect the radio chassis electrical connectors, the antenna lead, the three climate control electrical connectors and remove the radio chassis and climate control assembly.
  10. Remove the two heater outlet floor duct screws. Remove the heater outlet floor duct (18C433).
  11. Remove the four RH instrument panel lower reinforcement bolts and the RH instrument panel lower reinforcement (045F08), then the four LH instrument panel lower reinforcement and the LH instrument panel lower reinforcement.
  12. Remove the anti-lock brake control module (2B373). Refer to Section 06-09 for the removal procedure.
  13. If equipped, remove the speed control amplifier. Refer to Section 10-03 for the removal procedure.
  14. Remove the electronic door lock control processor (14B001). Refer to Section 01-14A for the removal procedure.
  15. Remove the passive restraint control module. Refer to Section 01-20B for the removal procedure.
  16. Remove the two center duct screws and remove the center duct (19D633).
  17. Remove the two ground wire bolts.
  18. Remove the three U-bracket-to-chassis nuts.
  19. Remove the four U-bracket bolts and remove the U-bracket.
  20. Remove the two RH and the two LH instrument panel bracket bolts and remove the instrument panel brackets (042C74).
  21. Remove the RH inner duct.
  22. Remove the LH inner duct.
  23. Remove the two accelerator pedal and shaft bolts and then the accelerator pedal and shaft (9725).
  24. Remove the accelerator pedal stop screw and then the accelerator pedal stop (9816).
  25. Remove the heater outlet duct screw and remove the heater outlet duct.
  26. Remove the temperature blend/panel bypass door actuator motor. Refer to the procedure in this section.
  27. Remove the panel/floor/defrost door actuator motor. Refer to the procedure in this section.
  28. Remove the three A/C evaporator register duct screws and remove the A/C evaporator register duct.
  29. NOTE: The A/C evaporator/blower motor assembly does not have to be removed in order to remove the heater assembly.
    Remove the four A/C evaporator/blower motor assembly screws to aid in the removal of the heater assembly.
  30. Remove the four heater assembly screws.
  31. Remove the heater assembly.
Sep 30, 2009 | 1996 Mercury Villager
I need to remove the cover on the gauges on a 2001
Instrument Cluster Removal and Installation Disconnect the battery ground cable. For additional information, refer to Section 414-01 . Remove the instrument panel center finish panel. Remove the screws. Disconnect the connectors and remove the instrument panel center finish panel. Remove the hood latch release handle. Remove the screws. Lower the hood latch release handle out of the way. Remove the instrument panel steering column cover. Remove the screws. Remove the instrument panel steering column cover. Remove the instrument panel steering column opening cover reinforcement. Remove the four screws. Remove the instrument panel steering column opening cover reinforcement. Position the column gearshift lever in the low position. Partially remove the instrument cluster finish panel. Remove the screws. Position instrument the cluster finish panel to gain access to electrical connectors. Remove instrument the cluster finish panel. Disconnect the connectors. Remove instrument the cluster finish panel. NOTE: Illustration shows steering column removed for clarity. Remove the instrument cluster. Remove the screws. Remove the transmission range indicator and position the cluster forward to disconnect the three electrical connectors on the back. Remove the instrument cluster.
May 15, 2009 | 2001 Ford Explorer Sport
The wiper blade connection has released from the wiper blade motor bar that controls the wipers movement. You can hear the motor working but the arms have been disengaged.
please rate as fixya if this is what you need. Mounting Arm and Pivot Shaft —Windshield Wiper Removal
NOTE: The windshield wiper pivot arms (17526) must be in the highest position to remove them.
  1. Turn the ignition switch (11572) to the on position.
  1. Turn the windshield wiper (17500) on.
  1. Stop the windshield wiper pivot arms at the highest position by turning the ignition switch off.
  1. Remove the windshield wiper pivot arm.
    1. Remove the pivot arm nut cover.
    1. Remove the nut.
  1. Raise and support the hood (16612).
  1. Remove the cowl grille seal.
NOTE: The two cowl grilles overlap at the center. The LH cowl grille must be removed first.
  1. Remove the LH cowl grille.
    1. Remove the screw cover.
    1. Remove the clips.
  1. Remove the RH cowl grille.
  1. Remove the mounting arm and pivot shaft.
    1. Disconnect the electrical connector.
    1. Remove the bolts.
Mar 14, 2009 | 2000 Ford Expedition
rss2search.com Logo
71 people viewed this question
Top rss2search.com Computers & Internet Experts
David Payne
David Payne
Are you a rss2search.com Computer and Internet Expert? Answer questions, earn points and help others
