Question about Meridian Point 6 in 1 Wireless Headphones For TV Stereo PC MP3 CD DVD Player FM
Won't have sounds on Pc.
I tried all the channels but none worked
Bios page won't function. I'm trying to Setup with F2 but none of the functions work. I'm using an EE pc 1005 HB.
Hello wmalvinx.
in the manual they say press F2 twice.
first press will show then post screen
sec. press open the bios.
mfg Gue
Feb 26, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Blue screen. Won't get any channels, or picture. Tried programing. Didn't work
It sounds that the tuner is faulty. Befror confirm it, a through checkup is necessary. Seek tech support.
May 24, 2012 | Prima C2012 TV
Why won't any universal remotes work with my LG tv?
The two possible reasons are:
1. None of the codes are correct for this model.
2. The remote infrared receiver in the set is bad.
(maybe the reason the other person got rid of the set?)
There are some ways around this depending on how you hook up and what you have for signal:
If a box (cable or sat) is connected to one of the sets of audio/video jacks on the set--switch to that input and change channels etc with the box!
Use the box remote for functions like channel and sound etc.
May 01, 2012 | LG 26LG30 26 in. LCD TV
Sound is garbled on one channel only-using antenna.
Try using a different antenna or moving the antenna to a different ocation. if none of that works you might have a bad signal board. You can get parts at www.interliquidparts.com
Dec 12, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
I have not received a diagram of my stylus wiring. none of the sites that was recommended have helped. do you know the purpose of each color of the four wires?
One is earth for the right, one is earth for the left, one is right channel and the other is left.
You don't need to know the colours to find the left and right channels. Just connect the turntable to the amp switch on. Then with your finger touch each wire one at a time. One will buzz on the left the other will buzz on the right. You might even get a slight buzz from the two earths.
The cartridge might have the left or right channels marked so you can connect them, but if it doesn't just connect the left to one side and the right to the other, then do the same with the earths. try it out, if the channels are the wrong way round change them, if the sound doesn't sound right change them again and again till it sounds right. You won't damage the amp or cartridge from doing this. Unless it's some kind of static effected cartridge!
Jul 30, 2011 | Audio Players & Recorders
Problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
Feb 25, 2010 | Sanyo DP50747 50 in. Plasma TV
My video clips have no sound
maybe u can try this one that easily to convert any video clips into different formats.
Jun 27, 2009 | Sony Vegas Pro 8 Professional Video ,...
I lost my sound on my HP Compaq D530 computer
Check the audio setting in the volume control in the accessories folder in the start menu.  make sure that all of the audio channels are switcched on, and thaty none of them are muted.  If this does not work, try uninsztalling the audio device in the Device Manager, and restart.
Jan 10, 2008 | HP Compaq Business d530 Small Form Factor...
No remote
heidib, if the front of the set has a menu button try going in and autoprogramming your channels, it seems odd that it won`t go above or below channel 2 which tells me none of the other channels are programmed in. Good luck
Nov 27, 2007 | Zenith C27A24T 27" TV
Meridian Point 6 in 1 Wireless Headphones For TV Stereo PC MP3 CD DVD Player FM Logo
41 people viewed this question
Top Meridian Point Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Meridian Point Audio Player and Recorder Expert? Answer questions, earn points and help others
