Question about Little Tikes Cozy Coupe
Need off put wheels wrong
Put on wheels backwards
    New Friend:
    Problem Solver:
  • 17 Answers
How have you installed it? screw or click? either way, you can slowly and carefully remove the wheels and put it back on. If you still can't, I suggest that you call the customer service of Little Tikes and you'll find their contact numbers at http://www.littletikes.com/
Posted on Jan 16, 2014
2005 Honda XR 125 L speedometer cable spins backward
Hi, Chris you have the speedometer drive unit on the wrong side of the front wheel for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
NEW HONDA XR125 XR 125 SPEEDO CABLE ALL YEARS eBay
Honda XR 125 Broken Speedometer Fix
Xr125l Bike 2003 2011 Workshop Service Repair Manual Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda XR125LK Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 21, 2018 | 2005 Honda XR 125 L
Drive wheels won't freewheel when pulling mower backwards,
pull off what looks like hub caps and check the wheel clutches
Apr 02, 2012 | Garden
I've got all the wheel nuts incl locking nut off my Golf back wheel, but can't get the wheel off, what am I doing wrong?
At a guess, you've got alloy wheels, assuming so, this is a common problem.
1) Make sure its on an axle stand, not just a scissor jack, and give the inside of the wheel a good old whack with a mallet, if you don't have a rubber hammer/mallet. Hold a piece of wood against the wheel and hit that.
or
2) Put the wheel nuts back on, just finger tight, then roll the car backwards and forwards, with luck the weight of the car should do the work for you.
When you put you wheel back on, put some copper grease on the hub to stop it sticking again.
Jan 30, 2012 | Cars & Trucks
Whats wrong when my front end has a wobble in a 95 camaro
The first thing I would do is to jack up the car and inspect the lug nuts to make sure they are tight. Then spin the wheels by hand and look to see if the wheel is bent any. If the wheel is bent it will wobble. Next spin it again and make sure the tires don't have any broken belts in them. If you have broken belts it will look like the tire isn't perfectly round, and the tire will wobble while the wheel runs true. On some models that use old style lug nuts they can be installed backwards. If you have what are called acorn lug nuts you can only put them on one way. If you have the old type the angled surface goes in. If these are on backwards the wheel can wobble. If this all checks out you need to look at the steering components, you probably have some worn out parts. For most people the front end inspection should be done professionally. This is because it is beyond the capabilities of most DIY people.
Dec 06, 2010 | 1995 Chevrolet Camaro
My rear tire seems to be offcenter.Which side ot the mag wheel should the valve stem be on? I suspect previous owner put brake rotor and sprocket on wrong sides causing wheel to be offcenter.
I don't think it can go backwards, the wheel and tire should have arrows on them pointing forward. Look at the hub, if it is identical on both sides, maybe you need to get out the measuring tape and find out if it was switched. But I don't think so, how about the bushings on either side? are they that same length? Check this stuff out. Hope it helps.
Apr 18, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Wheels on backwards on Phil and Ted Sport
get in touch with www.buggypitstop.co.uk they do repairs to phil n ted they may be able to help you. They are very helpfull
Nov 29, 2009 | Regal Lager phil & teds Sport Buggy Double...
My son put the small wheels in backwards. is
yes you can remove the wheel by pressing very hard at the top of the wheel or by using a screw drive to push it in. it's not easy but it can be done. or go to www.buggypitstop.co.uk they repair and service bugaboos
Nov 15, 2009 | Bugaboo Frog Stroller
I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
My four wheel drive doesnt work in my 87 s10 blazer , like when i put it in park to put it in gear the shifter on the floor goes into gear but the four wheel drive doesnt turn on ? is there any fuses or...
sounds like either a fuse or the do u have locking hubs that need to be engaged also when using 4 wheel drive there is actually only 2 wheels turning usually passenger front and driver back sometimes u also have to drive backwards to engage and also disengage 4 wheel drive finally it may be a transfer case problem check drive shafts and u joints make sure they are engaged
Oct 23, 2009 | 1987 Chevrolet S-10 Pickup
1996 Rodeo Isuzu - I put it in Winter Drive and now 1 rear wheel
Based on another similar problem and it was fixed driving backwards, that's exactly what I did. I drove the Rodeo backwards and then would stop and put it in gear and did this for 10 minutes until I worked the 4x4 gear loose and now all four wheels run. I must say, I created quite a sight driving backwards in a Wal-Green's parking lot for 10 minutes.
Jan 28, 2009 | 1996 Isuzu Rodeo
Little Tikes Cozy Coupe Logo
426 people viewed this question
Top Little Tikes Toys Experts
Jim Goldsmith
Jim Goldsmith
Adam Fjeld
Adam Fjeld
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
