Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Black and white screen when external device is plugged in via yellow red white cable connection
  • Sharp Master
  • 9,587 Answers
Make sure your connections to the TV are in the right place. Sounds like you're using the hi def connections when you should be using the analog connections on the TV
Posted on Dec 31, 2014
3 Suggested Answers
  • 298 Answers
SOURCE: iPod player won't show on screen of my Sharp LCD LC-46D62U
Connect direct to the TV and select
TV/video and see if that works
Posted on Dec 10, 2007
  • 8909 Answers
SOURCE: my dvd won't play in
I expect your new TV is looking for an S connected signal at least. You are connecting it using AV leads? Can you configure the TV to AV input instead of S video or Y-C?
Posted on Dec 18, 2010
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
See page 8 here:
http://cdn.vizio.com/documents/downloads/hdtv/M550SV/991UG_M420-470-550SV.pdf
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Nov 25, 2014 | Vizio Televison & Video
Connections problem
Question: What are the extra wires used for on the power cable for my fishfinder?
I found this on the carmin website under questions and answers. I think your cable is ok to use according to this.
--> Answer: Not all of the wires in the harness are required for use. To connect the unit to the power source, only the black & red wires are required (black to ground, red to positive). Here are descriptions of the other wires in the harness:
  • The Blue wire is used for a NMEA data out connection to another NMEA compatible device. The fish finder outputs NMEA 0183 version 3.01. The receiving device must be compatible with this format and looking for the NEMA sentences DPT, DBT, MTM, or VHW.
  • The Brown wire is used for a NMEA data in connection to receive data from another NMEA compatible device.
  • The Yellow wire is used to connect to an external buzzer or alarm to alert you to any alarms which have been set to sound on the device. The Yellow GARMIN wire connects to the negative end of the external alarm. The positive return on the alarm will connect to the red positive wire of GARMIN.
  • The green, white, and any other colors present have no connection purpose related to your fishfinder. The 18 Pin connector wiring harness is used by several other devices which utilize these wires.
If the device is only being connected to power & do not require a NMEA interface, PC connection, or external alarm support, only the red & black wires are required.
Jul 05, 2012 | Garmin Fishfinder 90
Format external hdd
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jun 30, 2012 | Hitachi Computers & Internet
I connected a speaker bar directly to my new LG TV. The speakers came with two audio cables ( red & white) and one video cable (yellow). I connected the red & white cables to both devices - red...
You can only get the television to recognize the external audio when connecting to its audio OUTPUT. If it does not say OUTPUT on the television where you've connected the red and white cables between it and the spear bar it is not going to work. You'll have to connect all your devices to the speaker bar with red and white cables and to the television with a yellow or green, blue, and red cable for video.
Aug 29, 2011 | Audio Players & Recorders
Plugging red to red, white to white, and yellow to SPDIF (black) and got no picture with sound. Plugging red to red, white to white, and yellow to green and got black and white picture with sound. How...
First you need a component cable to solve your problem.Since you have not mentioned what device you are connecting to your TV, I''ll assume its a DVD player or a settop box.There is a Red and White audio sockets + Red / Green / Blue component video socket. Just make sure you connect the corresponding two sets of jacks at both end of your TV & DVD player and everything will work. bobhifi_21.jpg
Mar 27, 2011 | Philips Televison & Video
I have an rt2870 and am just wondering where i connect the yellow subwoofer cord to the TV at, and i set my tv setting for the surround sound
You shouldn't connect the subwoofer to the TV. Just connect the Right and Left audio cables (red and white RCA plugs) to the TV audio out and then the other side goes receiver's audio in. If you are using the subwoofer that came with the unit, connect it to the sub port (purple and grey or black striped). The red and black striped cable goes to the subwoofer control.
If you are using another active subwoofer, connect it to the RCA jack labeled Subwoofer Audio OUT.
If you have a 3-plug RCA cable that is a composite video cable. The yellow plug carries the video, the red and white carry the audio signal. This cable is most often used for connecting older VCRs and game systems to a TV (or newer devices to an older TV). Thus leave the yellow jack dangling if using it for an audio cable.
Set your TV to use the external audio speakers and the receiver will take care of the signal to the subwoofer. (You only would connect the speakers individually for a computer sound system.)
I hope this helps.
Sep 19, 2010 | RCA RT2870 Theater System
My cable company gave me cable tv with a tivo. the box must connect to the TV via a 3 cord (red,white and yellow) wire the tv only has a coaxial plug.
You need this device to fix your problem, it is an adapter that takes the red white and yellow connection, and outputs it via coaxial plug, so you can just tune to channel 3 or 4 on your TV and it will work fine! Here is a link to the item you need:
http://www.amazon.com/gp/product/B0014KKV7W?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B0014KKV7W
Sep 10, 2010 | Televison & Video
I am trying to hook up this VCR to a digital TV and the cable has red, white and yellow but the back of the VCT only has white and yellow, what do i connect to which color?
Well I will tell you what the colours mean first. RED is right audio and WHITE is Left audio. YELLOW is Video.
I don't think it will matter if you plug the white or red into white, but the yellow must go into yellow. Is the device with white & yellow mono and not a stereo device? As that would explain why it's not got a red terminal.
Wouldn't it be better to connect via the scart socket, they must have both got one. If you are using the scart on the TV for something else, you could get one of these switching boxes from Amazon.
Aug 08, 2010 | Sharp VC-A410U VCR
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
