Question about GE Spacemaker JVM1640SJ Microwave Oven
Can't remove light bulb part from the fan unit. It's stuck!
The fan light on my spacemaker microwave is stuck in the socket. The bulb came out, but the rest of it is still in there. How do I get it out?
  • 323 Answers
Make sure the microwave is either unplugged, or if hardwired, turn the breaker off.
Spray a little WD-40 between the stuck base of the bulb and the socket and let it sit for a few minutes.
There are several ways to do this, depending upon how much room you have to get your hands in.
You can take a pair of needle nose pliers and open them inside the base of the bulb so that the ends of the pliers are jammed against the side, and turn to your left with both hands.
you can jam something like one plastic coated handle of electrician's wire cutters in the socket so you hold the other end and the friction gets it started.
Once you get it broken loose, you should be able to take of side of the socket with the needle nose pliers and grab hard, and turn to your left. As long as the power is off, you can't get hurt and you won't hurt anything.
Sirwriter
Posted on May 17, 2009
I replaced the light bulb under the unit on my microwave and went to turn it on and it tripped the circuit breaker and smoked the control panel. The only fuse in the unit is still good. Any thoughts?
< - Please let me know your full model number from the tag on the unit and I can can give you the repair information you need.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 05, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave. One of the lights does
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker JVM142K003 over the counter microwave and about a month ago the lights and exhaust fan stop working what can I do to fix this?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
prototech@usa.net
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My 3 1/2 year old ge spacemaker over the oven microwave with vent fan has stopped rotating inside.
Did the cooktop lights recently fail?
If so, then the problem is probably on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave lights flicker on then off
There must be a short in the wiring between the bulb sockets and the power supply or control board. Otherwise the short may be in the bulb sockets themselves.
I would test the connections to make sure the wires aren't loose and all solder joints are tight. If all wires look good, and bulb sockets are tight, then the problem may be faulty capacitor
Jul 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need new light bulb socket for GE spacemaker mircrowave
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker JVM XL1800
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Dec 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
383 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
