Question about Skytech M1 Hurricane Large 1:25 Scale Gyro Twin Propeller R/C Helicopter w/
Skytech m1 hurricane gyro helicopter
My son got this remote control helicopter for Christmas and although a red light comes on the charge box and remote control unit, NO lights or response comes from the helicopter itself. The instructions offer little detail or help. We have tried everything. Please advise.
    New Friend:
    Problem Solver:
  • 3 Answers
You ever find a fix for this problem?
I've got one too and I just noticed that the "green" charging light isn't coming on when it's plugged in to charge. I got the copter "used" and it apparently had a full charge when I got it home, but after using it and putting it on the charger over night, nothing. Reading the manual a little closer this morning, I noticed the "green" light is the "charging circuit: on" indicator. It's not coming on at all. (No, there are no switches etc.)
Here's what I'm going to do.
(Since we're dealing with Li-ion batteries, extreme care must be taken. Possible fire hazard. Follow these steps at your own risk. I am not responsible for any personal injury, or damage to your helicopter.)
THAT SAID! :)
The unit uses 3 wires to supply power coming from the charger.
One is for power (+), one is ground (-), and the other would be for the charging circuit (+).
Now, the reason for the above warning is because with any charging system, there runs the risk of fire, explosion, or acid leakage when improper charging techniques are applied. Li-ion batteries more susceptible to this type of damage than traditional Ni-Cad batteries, but that doesn't mean you can't recharge them yourself if you're careful. (Be warned, you may decrease the life of your batteries this way, but then again, what does it matter if you can't fly the darn thing anyway right?)
Okay. The charger's transformer (the part that goes into the wall) states that it pushes 5.6v @ 80mA into the batteries when plugged in. (Read: "Output" on the transformer.)
Since there is no additional output voltage listed, we can assume that this is the maximum listed amount of voltage and amperage that any one part of the system can handle at a given time.
Besides, the lower and slower you charge, the safer and better charge you'll get.
If you have a multi-meter handy you can do a voltage check on the wires to verify that your current transformer is putting out the correct voltage, but my guess is that like mine, it is not. (Most likely on the "Grey" colored lead.) Then check the voltages at the leads from the helicopter. (This tells you how much battery charge you have.)
That said, you have a couple options.
1. Use the transformer you have.
2. Find and use another.
Now we have to do something a little drastic here first. Unless you have a connector that fits the helicopter's connector (Check an old computer for one) you are going to have to take that little charging box apart and remove the one that's in there.
I don't suggest trying to splice directly into the wires of the helicopter as there is nothing wrong from the connector back to the helicopter. (If it ain't broke, don't fix it.)
Once you have this piece, follow the suggestions below.
1A. Using the one you have. - Since we know the "Red" wire and "Black" wires on your unit work, (indicated by the Red light you mentioned) you could simply splice the third "Grey" and the "Red" wires together PRIOR to the connector leading to the helicopter. This would divert power from the "Red" (power) circuit to the "Grey" (charging circuit) thus supplying power to the charging circuit. Now this will bypass the part of the circuit board that stabilizes the current in such a way that is safe for Li-ion batteries, but then again, most of these fixes are going to do this anyway.
2.A Find and use a different transformer. - Cell phones typically charge at around 4.3v to 5.6v. The power cords used to charge these devices can be found just about anywhere. USB ports charge at 5.6v as well.
Knowing this, you should be able to find a working transformer easy enough simply laying around the house. (Verify this by reading the "output" of the transformer you wish to use.)
Then, take the Black (-) lead and splice it into the Black lead of the connector (male) that is going to plug into the female connector of the helicopter.
Next, take the positive lead from the transformer and splice it into both of the other leads (Red/Grey) of the same connector.
Check your voltage output of all three connections. You should have positive voltage at both the Red and Grey leads, when the negative is touched.
Take a reading with your meter from the helicopter and write it down.
Assuming that you've done this correctly, find a well ventilated, fire resistant area to charge the helicopter and plug it into the female connector of the helicopter.
Watch the whole thing closely to make sure it doesn't catch fire and leave it alone for a bit.
After about an hour, re-check the voltage from the helicopter. If you notice an increase in the voltage here, you are charging your helicopter's batteries.
Continue charging until you reach the maximum votage of your battery pack. About 6v. (I think this battery pack is most likely a 6v setup.)
Once you have reached full charge, disconnect the charging unit from the helicopter and fly your bird! :) Repeat
Just to let you know. You can (if you don't go much higher) increase the output VOLTAGE of your transformer SLIGHTLY in order to decrease the charging time necessary to recharge your batteries.
There. We're done.
Let me know if this helps at all okay? I'd like to know how it all turns out for you.
Oh! Now that you've got a little info on how your bird works, it may be time to boost your birds power all around! lol But I digress.
Hope this all helps!
Any questions, post them here and I'll get back to you as soon as I read it.
Sincerely,
policetac
Posted on Dec 04, 2014
Syma S033G Helicopter does not lift off then stops
too much power,get a 7.4 volt battery and charge it to 7.4 volts,any more kills battery
Apr 16, 2015 | Syma S033G REMOTE CONTROLLED 3.5 CHANNELS...
My Gyro s107g helicopter won't connect to the remote. It just sits there not moving or any lights turning on.
It sounds like the two are not compatable. In other words the freakwinsy of the plane is not the same as the controller. THEY MUST MATCH. You may find the numbers on the back of the controller and where the batteries go in the chopper. If the numbers do not match, take it back to the store, and get one that does. Sorry for the spelling
Jan 13, 2015 | Syma S107G 3CH RC Helicopter RTF w/ Gyro...
On my gyro m1 it turn on and the remote to but i cant get it to spin the blade it make a buzz sound and stop i need to fly
THAT SAID! :)
There. We're done.
Sincerely,
policetac
Feb 01, 2014 | Skytech M1 Hurricane Large 1:25 Scale Gyro...
Idk if my last question posted but my son got a cheap looking Stinger Bladez with Gyro 3.5 channel r/c helicopter from a friend for Christmas. The remote has been plugged into the helicopter for four...
There are times when you need to check battery contacts on the copter itself, for at times there are plastic protectors between the batteries and the contact points that needs to be removed, these are used to prevent battery power drain while in storage or there might be an on-of power switch on the copter that you might have missed. if all else fails then this definitely is a dud but at least try to make it run ...
Dec 28, 2013 | Shuttle 9094 Emax Remote Control...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
I HAVE A M1 HURRICANE HELICOPTER AND THE LIGHTS COME ON BUT IT WILL NOT FLY. CHANGED THE BATTERIES IN THE REMOTE BUT STILL DONT FLY.
Using a multi-meter, check the voltage of your helicopter's batteries to verify that you have a charged battery pack.
If so, verify that your battery is connected to your helicopters circuit. There should be a white plastic connector that plugs the battery pack into the helicopters on board systems.
If everything is connected correctly and you are reading a very slight voltage from the helicopter's battery, then most likely you are not getting a good charge coming from your power charger. If this is the case, go here:
http://www.fixya.com/support/t23269551-gyro_m1_turn_remote_but_get_spin_blade#answer
Hope this helps.
May 29, 2013 | Skytech M1 hurricane large 1:25 scale gyro...
No power
Check the channels and make sure your on the right channel A / B usually..
give the blades a gentle turn with your fingers, they stick sometimes.
Dec 28, 2012 | FocalPrice BR6008 3.5-channel Infrared...
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Nov 19, 2012 | Syma S301g Rc Helicopter 18" 3 Channel Rtf...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
Skytech M1 Hurricane Large 1:25 Scale Gyro Twin Propeller R/C Helicopter w/ Logo
193 people viewed this question
Top Skytech Televison & Video Experts
Electro Med Services...
Are you a Skytech Televison and Video Expert? Answer questions, earn points and help others
