Question about Diadora Mens Grey Dial Dual Time Display Black/ Yellow Rubber Digital Watch
I need instructions on the wrist band adjustment on a Diadora dd.6087m/02 watch
Wrist band adjustment
I need to know about the warranty for my Diadora watch I want to contact The company
It depends on where you purchased it from. http://www.jomashop.com/diadora-watch-6126m-03m.html
You should be able to contact the store you purchased it from for further instruction
Jun 23, 2015 | Watches
My Diadora watch stopped working who do I contact,the watch was a Christmas gift
There're a lots of watch repair shops. Ask them they have more information and even can fix it
How do I make the watch band smaller?
to adjust the size of your wrist...eat chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
Can't adjust the wrist band on citizec C651
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist.
If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Oct 21, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I just bought a diesel watch from ebay model no DZ7068 and for some reason the wrist band doesn't tighten.. i got confused is there any solution for this? thanks chris
mcdevito75 here, Without seeing the watch NO. Best Bet, visit a small watch repair shop in your area and see about band adjustment, Most likely your missing something on the band you have to use to adjust for your wrist size.
Jun 28, 2010 | Watches
How do I adjust my watch band?
If you want to deuce the size of your band then I have found some instructions on the Fossil website and since most watches are very similar you can try the method described there.
If you need to replace links then you can get them for Skagen (free!).
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions"
Feb 14, 2010 | Skagen 355LGSC Wrist Watch
Resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Jan 10, 2010 | Watches
Band adjustment
Use a pick tool and push the pins out the sides in either direction of the arrows.
Nov 17, 2007 | Fossil CH2331 Wrist Watch
Remove few pieces in my Casio AW-SD bracelet
What u can do is call casio tech support and give them ur email address and they can send you the instructions to adjust your band.
Jun 07, 2007 | Casio AWS90D-2AV Wrist Watch
Diadora Mens Grey Dial Dual Time Display Black/ Yellow Rubber Digital Watch Logo
Top Diadora Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Diadora Watch Expert? Answer questions, earn points and help others
