Question about Optics
760 pumpmaster Seems to pump ok and expell air ok and chamber BB ok-but does not fire the bb
2 Suggested Answers
SOURCE: bb gum wont pump up
Open the pump arm (fore stock) all the way and check the rubber O-ring for cracks. If it's just dry, get some Pellgunoil® Lubricating Oil or the equivalent from a gun/sporting goods store and oil it.
Posted on Nov 04, 2008
Daisy Pumpmaster 760. How do I reassemble?
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/C760-OM1.pdf
Crosman Super. ' Pells® or Crosman Super. BBs®. Reservoir ... 'WARNING: Pelletsshould never be-put F'6_ into the BB Loadlng Port . They will iam ... BB How To Load Your 760 Rifle with ... see REPAIR SERVICE section of this manual. ' '.
Crosman 760 Pumpmaster assembly - YouTube
? 3:56
https://www.youtube.com/watch?v=OeOLKDYnGoE
Nov 16, 2008 - Uploaded by stonie stonemaker
Crossman 760 Pumpmaster air rifle in pieces? ... I can't close the bolt there's a little metal part that's not ..
Dec 25, 2015 | Optics
Why won't my new 1911 BB expel the BB's?
make sure you have a fresh canister in the handle, tighten the wingnut at the base of the grip until you hear the air pressurize the chamber, check the magazine to make sure its fully loaded, and disengage the safety switch.
Oct 01, 2015 | Miscellaneous
Is it ok to store the pumpmaster bb gun coke so the pump action stays put or will it ruin the seals
Only for short periods as the pressure will misshape the seals over time
Aug 17, 2015 | Optics
My granddaughters 760 pump master will not hold air pressure. When you pump the handle it makes a funny noise such as rubbing the side of a ballon filled with air. The BB just falls out of the barrell. Can...
Hello, I'm not sure why you wrote under this other guns listing. The Crosman Phantom .177 Caliber Break Barrel Air Rifle is a single break action pump and it only shoots Pellets. also much nicer than the 760 pump master, but, it also costs more than 2x's as much.
as for your problem with the 760. sounds to me like it was not maintained well. If You have tried this already ( Crosman Pellgunoil® Air Gun Lubricating Oil ) and it did not work. You can assume that little BB gun is probably broken, the air compression chamber have popped a seal most likely.
if You haven't tried that, oiling the gun then I suggest doing that and maybe it's not too late. There really isn't a lot to be done on these cheaper models of BB guns.
if the BB gun is not years old, just purchased, and Amazon buy, or something else cool like you have a wal mart receipt for it or even if you don't have a receipt and you just want to exchange it. ( i will explain that in a minute ) then I suggest you try sending it back.
If You bought it at a store`, you don't have a receipt. do this if you feel you did nothing to deserve this broken gun.
go back to that store and buy another one, exactly like that one. with cash or card. save your receipt, take the gun home, get it out of the package and use it and take care of it according to the directions. in a day or two take the broken one and the box from the new one back to the store and tell them you want a refund and they will credit your card back Or if you paid cash they will give your cash back. This method of return eliminates the possible bad mood or cranky manager that COULD turn your request down because of no receipt.
This is a great answer to your problem isn't it? :O) Hope it helps.
Mar 09, 2015 | Crosman Phantom .177 Caliber Break Barrel...
I just got my son a crosman 760 pumpmaster bb gun and we cant figure out how to shoot it. we loaded it, but for some reason it isn't shooting the bb's out
Are you pumping the gun??? Once you have bb's in the gun you have to **** it and then pump the foregrip 10 times then pull the trigger.......
Apr 24, 2011 | Sport & Outdoor - Others
I work the lever to load one BB. then pump 6 or 7 times. BB will not shoot out. When I pull the trigger, it sounds like it is shooting, but no BB comes out. this is for a crosman 760 pumpmaster. it...
Can you see through the barrel? Or run a rod down the bore? It sounds like the BB is either falling out the end of the barrel or the BBs are getting jammed up in there. Do not hold your hand in front of the barrel to see if any air comes out. You might get stung with 10 BBs. Hope this helps.
May 22, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
Out of order
from a gun shop
Nov 03, 2017 | Crosman (4032)
Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Apr 05, 2009 | Toys
Bb gum wont pump up
Sep 16, 2008 | Crosman (4032)
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
