Question about Sewing Machines
Kenmore 158 14001
How can i reset the shuttle race cover and shuttle back after cleaning my kenmore 158 machine
SOURCE: Kenmore 385. 11607 needle jams into shuttle or shuttle race
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Posted on Feb 05, 2009
kent581
  • 87 Answers
SOURCE: Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Posted on Mar 18, 2009
SOURCE: bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Posted on Sep 03, 2010
  • 1788 Answers
SOURCE: The first time the machine
Take it to your nearest Sears store and go right to the sewing machine department, they are usually very helpful and can tell you if it needs service or not. Take your manual with you.
Posted on Sep 11, 2010
aeroseek
  • 55 Answers
SOURCE: I oiled my Kenmore 1400
The link shows a photo of the bobbin assembly. Its sounds like youve left the latches open that secures the assembly.
http://sewingmachine221sale.bizland.com/store/page40.html
Posted on Dec 12, 2010
How can I put back the suttle race cover and the suttle after I oiling them. In the manual dosen't clear.
Look at the race cover... it's got a couple of matching dents in one side where the little plastic "bunny ears" fit into them. The shuttle goes into the race, then the race cover goes over the shuttle, and you move the little plastic bunny ears into position to hold the cover -- the tips fit in the dents.
Then put in the bobbin in the bobbin case.
It's very much like this: http://www.manualslib.com/manual/85659/Kenmore-385-15208.html?page=68
May 14, 2014 | Husqvarna Husky 145
Shuttle race wont move
We don't know what machine you have.
Jan 25, 2018 | Sewing Machines
I took out the bobbin case and then the shuttle race. Now I can't remember which one I should put back in first.
Clean the shuttle area, the hook and the cover with a toothbrush, removing all lint and debris. Place one small drop of sewing machine oil on the rim of the hook. Place the hook back in the raceway and replace the cover. Snap the two retaining levers back to hold the cover in place.
Jun 02, 2011 | White Sewing Sewing Machines
I need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Jan 25, 2010 | Sewing Machines
Where is the shuttle race on a Bernina Artista 180? I'd like to be exact as to where to put the drop of oil.
Just to the left of the bobbin case you will see a small lever. Remove the bobbin case and push the lever and that will release the latch which holds the race cover and shuttle (hook).
Clean well with a toothbrush and place one small drop of oil on the edge of the hook where it makes contact with the raceway. Place the hook back and snap the race cover back on.
Oct 01, 2009 | Bernina Artista 180
Bobbin and shuttle case pop out of machine .
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Kent
Mar 16, 2009 | Baby Lock BL1556
Dec 17, 2007 | Kenmore Drop-In Bobbin 505S-21BH...
Shuttle hook
Hello ZAckofun
The shuttle hook will be covered by a plate called the RACE. Its a flat steel plate that sits over the hook and is snapped in place by 2 black coloured snaps.
Looks like you are trying to operate the machine without the race on. try that and it should work.
Nov 27, 2007 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
