Question about Zanussi Washing Machines
POMPA PER ZANUSSI LB161E - Zanussi Washing Machines
I can not find a manual for model number ZE0505X
Susan, in what country did you buy the oven? The codes differ per country.
Does the model tag look like this?
Of course it might be difficult to FIND the tag...
Let me check where they stick those....not-find-manual-model-number-ze0505x-cluqxvqmjdhmibjs3bae0uvv-4-2.png
See above location in red.
You can lookup manuals on zanussi.com by using the PRODUCT CODE as well (the serial number does not help). Check if the product code gives you a result on this page:
http://www.zanussi.co.uk/Support/Manuals/
May 18, 2015 | Zanussi ZHQ575 Electric Double Oven
Hi, my Zanussi zdf511 doesnt seem to be adding any rinse aid on any of the rinse aid settings?
Rinse aid dispenser can receive a maximum level of 140 ml rinse agent. Consumption rinse agent could be per wash cycle of 2 to 7 ml depending on the settings.
Thus 140 ml is enough for 20-70 wash cycles, depending on the degree of adjustment.
Dado
Dec 02, 2014 | Electrolux Genuine ZANUSSI ZDF511...
Necesito diagrama de pompa de gasolina
Favor enviarme mas detalles.
Gracias
Jul 14, 2014 | 2002 Nissan Quest
Donde se necuentra ubicada la pompa del agua de una caravan 96
Try this sight to translate this into English http://translate.google.com/m/translate?twu=1 The 3.0 liter has a water pump that is timing belt driven it is located behind the timing cover. The 3.3 and 3.8 are both located in the bottom of the engine closest to the radiator. You can follow the lower hose to the backside of the water pump housing. The water pump will be on the other side.
Feb 07, 2012 | 1996 Dodge Caravan
MICROWAVE ZANUSSI ZNF31X SYMBOLS ARE NOT CLEAR AS PER MANUAL
HAVE YOU REMOVED THE PROTECTIVE POLYTHENE COVER ON THE DISPLAY PANEL?
Dec 31, 2010 | Microwave Ovens
Mi maquina luego de varias horas de uso la presion bajo totalmente . mi maquina es una excell de la honda modelo vr2522
Dispense porque mi espanol no es muy bueno aci como usted. El presion comiensa con el nozzle. Nozzle debe de ser el que fue hecho para la machina. El nozzle debe de tener el numeracion de gallons por minuto marcado. Su machina sera marcado con (gpm) gallons por minuto. 2.5 or 3.0 or 3.5, Y si el abuhero de el nozzle es muy grande, no va tener presion. Tambien, no debe de tener agua tirandose de connections. Y se el presion es muy bajo con el correcto nozzle, va a tener que combier partes adentro de la pompa. Y si ya tiene bastantes horas corridas, sera mejor combier la pompa entera.
Nov 10, 2010 | Karcher 2500 PSI Pressure Washer
Washing Machines Logo
56 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
