Question about Acer Predator Computers & Internet
Not loading on monitor, Acer Predator G3605
When we turn on the computer, the monitor just shows Acer screen and stays there. Nothing else loads.
McIndia
  • 131 Answers
SOURCE: New Acer Aspire E700 does not load-up
Does your BIOS POST runs then you might be having a Disk Booting Problem, If you dont see your BIOS POST Screen, then check if you can hear any beep sounds, If you hear beep sounds check the ram whether it is properly inserted in the ram slot or the ram might be faulty.(You may have to change the Ram). If you dont hear any beep, check whether the buzzer(Speaker in the CPU) is working, If buzzers were working fine before, then you might be having problems with your mother board or processor. If you know how to work on such problem try reinstalling the processor, ram etc in the cpu . Otherwise call a service engineer to have the job done.
Posted on Jan 01, 2008
  • 6 Answers
SOURCE: Monitor on Acer staying gray
have you tried to the "function+8" (or the number to transfer the signal to a monitor) when you are on the laptop with grey screen?
Did you said that grey, means that there is light on the laptop, but no colors, or that tha screen is not turned on?
Posted on Jan 09, 2008
mewms_14904
  • 1027 Answers
SOURCE: ACER Aspire 3003
You may have to use eRecovery manager. This will reset to default.
to access erecovery <ALT> <F10>
Posted on Apr 21, 2008
SOURCE: computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Posted on Jul 14, 2008
  • 33 Answers
SOURCE: ACER X193 MONITOR DISPLAY ISSUE
Windows doesn't know your display is broken as it see's your display adapter for the laptop. By adding the monitor windows is adding a second display to the one you don't actually have, your icons and start bar are still on display 1
sorry
Posted on Sep 28, 2008
My Acer Aspire V5-571 does not load up it shows acer screen when turning on the laptop then loading floating ball comes on screen for a few seconds then black screen ? can any one please help ?
Hi Jim,
this seems like a no boot / no video kind off issue and mostly is coz of corruptions in softwares or drivers, try booting the computer in safe mode. if it does, then take a data backup. i would not recommend experimenting in this issue as it can crash the computer.
hence call 1-877-805-1027 for expert help.
Aug 18, 2015 | Acer Aspire V5 571-6614 : 1.6GHz Core i5 ,...
Aspire 5349 Windows 7
harry not a joke but this happen many a times.
dont know d reasons. but try with win xp.
Format c drive properly.
then if you want upgrade with win7..
Dec 17, 2012 | Acer Computers & Internet
Hi. I have a acer aspire 5520. After Bios is loaded, show a black screen with a blinking cursor. And not make nothing anymore. Regards.
This is either an issue with the HDD or the OS
Turn the computer on and when you see Acer press ALT + F10 together.
You should see Windows is loading files and then load into the Acer eRecovery Manager.
If you don't then its a HDD fault.
Apr 26, 2011 | Computers & Internet
Screen Turn's on.You seen Acer load up Splash Screen for less then a min, Stay on until Windows Xp Load up screen then goes into sleep mode. Encontered same problem when I connected Xbox360 with HDMI to...
  • Hello chaleebradsh, the "Monitor" as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. "I hope this information is of help; thanks for using FixYa, paul7of9"
Jan 31, 2011 | Acer AL1717 17" LCD Monitor
I have an Acer AL1916W the power switch lights up brightly but when computer is switched on switch goes dull and and screen stays blank...Found two Capacitors that were bulging they were 220mf 25volt....I...
Can you send me a picture of the boards in your monitor? We work on Acer units all the time.
Buddy
Corporate Computer
www.ccl-la.com
buddy@ccl-la.com
Over 21 years of PC and printer support/repair
Jun 28, 2009 | Acer AL1916W 19" WideScreen LCD Monitor
After loading windows Vista screen says no signal
steve, i dont think there is any problem with monitor. restart ur pc in safe mode, change resolution to 1440X900.
Mar 02, 2009 | Acer AL1916W 19" LCD Monitor
No signal input
Check the coolant between the CPU and the cooler to ensure it's not simply over heated.
May 30, 2008 | Acer AOpen AX 6B Plus (91.87810.321)...
Jan 09, 2008 | Acer Aspire 3000 Notebook
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Computers & Internet Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
