Question about Kenmore Vacuums
Can't get the vaccum cover off to see if there is a broken belt.
Do not know how to take the cover off to see if there is a broken belt.
    Scholar:
  • 65 Answers
IF it is a standard style vacuum, then there will normally be between 5 and 7 screws that need to be removed, the the cover can be pried off (usually by depressing 2 locking tabs
I did not read theentire problem because it wasn't allowing me to read the whole complaint so I presume you are trying to replace a broken belt?
Posted on May 18, 2009
My nearly new Miele S710 vaccum cleaner just revs like mad when you switch it in but you get no suction. Could there be a drive belt between the electric motor and the vaccum pump that has come off or...
Yes this could be a case due to which there is no suction. I am posting an article which gives you a detailed description of how to open it and repair the internal parts.
http://www.sannerud.com/house/miele.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 23, 2010 | Miele Vacuums
BRUSHES WILL NOT ROTATE
Remove side cover below is a small piece of red plastic with screw attatched check to make sure belt is not broken or for some reason come off. Could be hair build up or your vaccum cleaner is not picking up enough dirt and debri causing it to clog. Steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The power bar stopped working. The vaccume is
If its 2 months old I wouldnt stress looking at anything. Box it up and take it back. Something that flimsy doesnt make sense to keep does it?
Apr 29, 2010 | Hoover S3765-040 WindTunnel Bagless...
Brush won't turn but belt is not broken
DC07s have two belts - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
I suspect the belt you are to refering to is the one from the clutch to the brush bar. Unfortuenately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay2_bing.gif reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing your machine, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Apr 24, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dyson all floor vaccum no suction when hand held wand is turned on... doubled checked for cracks in hose -- none took house off unit to check for blockage --- none.. suction works fine when using as normal...
You need to replace the belt that drives the brush on the underneath side of the vacuum. To do this, you need to flip the vacuum over and remove cover plate. There you will find the broken, or stretched out belt. Remove the brush and place the new belt on the chrome axle. Then put the brush on, rapping the new belt around the brush as you put the brush back in place.
Jim
Jun 09, 2009 | Dyson DC14 All floors Bagless Upright...
Bottom on the vaccum the spin brush will not spin at all
Double check for anything that might be holding it from spinning (shoe lace, string, hair, ribbon, etc)
If the brushes are free to move by hand, you most likely have either a broken belt or a belt that simply came off the motor. What you'll need to do in either case, is open up the vacuum cover. The screws are usually located at the bottom of the vacuum (where the brushes are) and remove all the visible screws you see.
Most of the time (being that I don't know what kind of vac you have, that is enough to remove the top cover off for you to inspect either the motor or the belt which attaches to the motor. I know on my hoover, the belt slips off very easily, so I always need to keep my screwdriver handy to perform this.
Hope this helps.
Apr 19, 2009 | Vacuums
Hello . The beater bar is not spinning on my Hoover bagless upright rewind. Can I fix this?
very simple to repair its a broken belt read owners manual or somtimes they print instructions on the head of vaccum belts are sold at walmart you must know make and model or get number of old belt. before buying one check the back where the attachments are some cleaners have spare belts
Jul 20, 2008 | Hoover Vacuums
Vacuums Logo
152 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
