Question about Hardware & Accessories
Tighten cabinet hinge
Door swings open to easy. How can I tighten this hing?
    Filmmaker:
    Uploaded 5 video answers.
  • 7 Answers
If this has always been a problem I would have to assume that your cabinet is out of square or not level, after that is checked and ruled out I would go ahead and change the hinge as it might be faulty. Tighten cabinet hinge - 2_18_2014_5_14_03_pm.png
Posted on Feb 18, 2014
How do I remove oven door
open the oven door all the way and look down at the hinges. there is a little locking clip that you swing into position that locks the hinge from closing. it might be stiff and need some cleaning depending on how old and dirty your oven is. Also you might have to push down on the oven door to make the hinge open fully to get the locking tabs into place. making shore that the locking clips stay in place and hold open the hinge as you lift the oven door slowly towards its closing position and you will see the whole hinge lift up from inside the oven cabinet and the door will just lift out. be careful not to catch your fingers. make sure the looking tabs stay in place during removal as the hinge is very hard to get back into this position again. re fitting is the reversal making sure that you have pushed the base of the door all the way back into the cabinet and push down on the as to open it to release the tabs.
Sep 23, 2016 | Ovens
Tip
How to Reverse Your Refrigerator Door (Most units)
1. Remove the toe grille.
2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside.
3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin.
4. Lift the refrigerator door off of the bottom hinge and set aside.
5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws.
6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge.
7. Remove two screws on bottom hinge with 3/8" socket wrench.
8. Install bottom hinge on opposite side with the two screws removed from Step 7.
9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench.
10. Reverse door handles.
11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam.
12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole.
13. Tighten center hinge pin with adjustable wrench.
14. Remove cabinet and hinge hold plugs and move to opposite side.
15. Lower freezer door onto center hinge pin (if you have a separate freezer door).
16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge.
17. Flip top grille and reinstall.
18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
on Oct 19, 2011 | Frigidaire Refrigerators
Tip
How fix cabinet hinges quick and easy.
If you've ever had a kitchen cabinet door hinge fall off or get loose due to a wood screw stripping out. This can be fixed very easily with a golf tee or toothpicks. Just remove stripped screw and expose screw hole. Put golf tee or toothpicks in hole and break off even with surface. Now just replace screw in the original location and the toothpicks or tee will tighten up screw like new.
on Oct 10, 2010 | Home Fencing
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Car door shuts too fast
the hinge has anchoring bolt and pin somewhere around the inner arm part of the hinge. tighten the bolt by the closing armature. also a body shop could easily remedy this with one of their wrenches ok?
Jul 25, 2009 | 1999 Oldsmobile Alero
Driver Door Adjustment
Remember that there is a little play in the hinges, even new ones, enough that just a slight degree of play at the hinge axis will result in several fractions of an inch movement at the latching end of the door. The key here (assuming the lower hinge is still mounted at factory height with respect to latch) is to adjust the angle of the hinge's axis such that the latching mechanism is 1/2 inch higher than the stiker plate BEFORE tightening down the hinge's mounting bolts, then when you remove your support holding up the latch end of the door it should sag back down approx 1/2 inch and line up perfectly with the latch plate. I used to do this on an old '79 Monte Carlo I used to have and even being the smallest of the Monte's, it still had fairly long, heavy doors for back then even and could get the doors to shut/latch perfectly. I own a VUE now-a-days and its door's are featherweights by comparison so they should be fairly easy to adjust and you shouldn't have to tighten the @#$% out of the mounting bolts during the adjustment, just make sure you tighten them good when the alignment turns out correct upon final inspection.
If your adjustment sags again after shutting the door a few times, then you didn't tighten down the hinge mounting bolts enough and will have to go through the adjust procedure again making sure to tighten things up better the 2nd time around.
May 26, 2009 | 2004 Saturn VUE
R/H door swings open too easily and hits counter behind door.
Hi LC,
Your fresh food lower door hinge cam assembly has failed and needs to be replaced. Not a big deal to replace, really... but you have to remove the FF door to get to it. <---which is VERY simple to do. But first thing first, right? You'll obviously need the replacement part on hand prior to the repair, so the part number is WR02X10779. You can see what it looks like here (you could also order it here if you don't have a local appliance parts retailer).
OK, now that you have the cam assy., Empty out all the goodies that you have stored in the FF door shelves. Then using a sturdy step stool, remove the upper hinge cover. Below the cover, you'll find three more screws, remove them (just so you know ahead of time... after you remove the last of the 3 screws, the door is no longer "attached" to the frame, so hold on to the door while removing the last one, OK?). Now all ya have to do is lean the door forward (from the top) and lift it off of the lower hinge/cam assembly.
Now that the door is off, all that's left to do is remove the old cam assy., install the new one and rebuild everything! Easy Breezy! You'll be in and out of this job within 20-30 minutes.
Oh yeah... one other thing. When you replace the door and are putting the top hinge back on, put all 3 screws in but don't tighten them yet. You'll need to "level" the door and THEN tighten them. Just lift the fridge door handle 'til the top of the door is level with the Freezer door, tighten the screws while holding the door in this position, deal? Cool.
Hope this helps!
SG
May 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Apr 11, 2006 | Electrolux EOG9330 Gas Double Oven
Hardware & Accessories Logo
508 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
