Question about Philips 50P8341 50" Rear Projection Television
Tv color is dark, and there is lots of green in the picture
50p8341a ------wasnt sure what part we would have to replace in order to get the color right.. if u could let me know what part so that i may replace it.
  • Philips Master
  • 8,617 Answers
Sounds like the coolant needs replacement. You can tell by looking into the lens of the CRts while the set is playing. The green and blue are usually the ones that are affected first. If you need to know where to get the coolant kit which contains the coolane and the instructions let me know and I will post the link.
Posted on May 17, 2009
Toshiba tv has dark picture cant hardly see want get bright
If it's a old style projection screen pry off front grid, you,ll see a trapezoidal mirror this often becomes hazed smoke, dirt, ect. Make sure set is unplugged DO NOT ASSUME THEIR IS NO SHOCK HAZZARD BECAUSE SET IS UNPLUGGED(see capacitors) be careful and clean mirror with damp cloth and glass cleaner try not to spray as safety percotion, their are 3 tubes red , green, blue, green is th dominaent color if you know how turn blue HVU UP 1st( CLEAN picture tube lens 1st) These type of picture tube have clear poly glycol ( anti freeze) in lens unit to cool and is part of the optical system. I this fluid becomes contaminated then cost of repair may exceed value of unit, then increase red value I just thought you may bee able to do the color via menu not sure, if picture has a green tent at start this should help good luck , lot me know what you see.
Aug 18, 2014 | Televison & Video
Too much green dont have orginal remote. Is there
your tv needs repair one of the transistors on the neck board is bad..the neck board is connected to the picture tube end inside the tv..but be care full as it stores very high voltage.if you are not a tech have a tech look at it.
Jul 11, 2010 | Zenith Televison & Video
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The dark color of my tv was change unspected the dark color now are blue, violet,and other exept black, the dark scense can't see. please help me.
I believe you either have a bad LCD Controller Board or a bad Main Board. The only way to know is to replace one. If it doesn't fix it , replace the other. Or replace both and it should be fixed.
I hope this helps,
Skyassoc
Nov 03, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
Picture suddendly changed to "photo
hi! your lcd cpu is defective, here in the philippines we try to re heat the cpu and it works.
Sep 04, 2009 | Insignia 42" Flat-Panel Plasma HDTV
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
PHILIPS 50P8341A COLOR PROBLEM
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Philips model 50p8341a projection
color is off. Faces are orange sometimes, all orange, or red? Tried the remote to fix however did not work.
Nov 22, 2007 | Philips 60P8341 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
