Question about Toshiba 50A60 50" Rear Projection Television
Toshiba 50A60 Projection TV - Black Screen
Hi, we have a black screen with sound on a 9 year old Toshiba 50a60. What do I look for? Is it just a bulb?
  • Toshiba Master
  • 10,291 Answers
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
Posted on May 29, 2016
ctf1800
  • 4402 Answers
SOURCE: skewed picture
Convergence problem.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 11, 2007
  • 133 Answers
SOURCE: Toshiba 50A60
Your best bet, and the cheapist, is to go on craigs list, an look for the same size tv, doesnt matter what brand, get one that doesnt work, probabily can find one free, or verry cheep, then just swop out the screen
Posted on Jan 08, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: need to clean inside of toshiba 50a60 model screen
TAKE THE SPEAKER GRILLE OFF FROM THE FRONT REMOVE 3 SCREWS LIFT UP ON THE SCREEN AND REMOVE IT TO CLEAN
Posted on Aug 24, 2009
SOURCE: Good morning, I need to clean inside of my Toshiba
Yes I Had The Same problem , if your handy with fixing things this will
work.
Step 1- unplug the TV from wall socket
Step 2- disconnect all devices like VCR's DVD Players from the TV
Step 3- remove the speaker covers from the TV
Step 4 - There are 14 screws on front cover, remove these with a
Philips driver, set cover aside
clean with soft brush and wash with water
Step 5- Gently raise the cover straight up to release it from its supports
Once cleared from supports , remove the cover.
Tips- Make sure you don't scratch any of the screens or CRTs
You can clean the mirror with any glass cleaner, make sure to wipe it
clean , water and vinegar does a good job to eliminate streaks.
Use a soft duster to clean the dust from the circut boards
Tip - Remember take it easy when cleaning
When your finished cleaning, just reverse the steps
It Worked for Me
Posted on Feb 17, 2010
Testimonial: "It came in very handy!!! Thank's for taking the time to write me the tips. Even if I got the answer to my problem 5 months later.Thank's again Lanzer"
joeymille916
  • 143 Answers
SOURCE: I have Toshiba Theaterview 50A60
http://www.partstore.com/ give them a call. If they don't have it, the can tell you where to get it or maybe order it special for you. Good luck!
Posted on Oct 09, 2010
How do I change the bulb?
http://www.manualslib.com/t/toshiba+50a60.html
Dec 21, 2015 | Toshiba 50A60 50" Rear Projection...
I have a 50A60 toshiba 50 in rear projection tv I have a green screen no pic but I have sound
Is there a cable or Satellite box hooked up for signal?
How and where is signal connected to the TV?
Dec 13, 2012 | Toshiba 50A60 50" Rear Projection...
I have Toshiba Theaterview 50A60 projection TV ( built April, 2001 ) with a broken front screen. Anyone know where to find one??
Oct 09, 2010 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60
Jan 08, 2009 | Toshiba 50A60 50" Rear Projection...
Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
Mar 13, 2008 | Toshiba 50A60 50" Rear Projection...
Skewed picture
Dec 11, 2007 | Televison & Video
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
Nov 26, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60
This are the part #s for the screens 23430784 fresnel 23430783 lenticuclar . the screen protector just measure the size and go to home depot and they can cut the plexiglass for you. to get the parts go to this link .http://www.vancebaldwin.com/
Jun 24, 2007 | Toshiba 50A60 50" Rear Projection...
TOSHIBA 50A60,GOING TO REPLACE LENTICULAR SCREEN
It's pretty simple repair.  Pull bezel, unscrew braces around edges and swap screen out.  Where did you find the lenticular at?  I have the same TV and can't find the part online.
Thanks
Mar 08, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 50" Rear Projection Television Logo
160 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
