Question about JVC Televison & Video
How to change a ir sensor in a jvc television
How can I find replacement TV Parts
Check Amazon or eBay. Put in your model number or the circuit board part number. You might be able to find used ones. Good luck!
Feb 04, 2016 | JVC Televison & Video
Tv volume control
Since it works when close, more likely the battery in the remote is running low, or you have some dust over the remote sensor on the front of the tv panel.
Mar 08, 2014 | JVC Televison & Video
Where is the ir on the jvc LT-47x899
Usually the IR receiver is located on the same board as the controls on the front of the TV or the same as the LED lights. If you suspect the IR sensor as being bad here are the part number for the control and LED pcbs. Please take a moment to rate my answer. Thanks..
CONTROL PCB: SFL-7224A-M2
LED PCB: SFL-8733A-M2
Nov 24, 2009 | JVC LT-47X899 47 in. LCD TV
Remote stoped working
Have the remote IR Sensor on the television replaced.
Part is very inexpensive.
Oct 12, 2009 | JVC AV-36D303 36" TV
Remote control (i hope)
The IR sensor in the tv is probably weak, you could make a mountain out of a mole hill and get it replaced (using your friends receipt ^_^) but there's nothing to be done about the sensor.
Feb 05, 2009 | JVC LT-32P679 32 in. LCD TV
JVC HD-61G787 IR receiver location
I took the front of the tv off. the IR receiver is beside the lens. I stuck the IR emitter directly on the receiver and reinforced it with hot glue and then fed the cable out through the back off the tv. Not a hard job just lots of screws.
Dec 13, 2008 | JVC HD-61G787 61" Television
Tv does not react to any remote-including original remote, cable remote, universal remote, etc
As you have probably tried changing batteries. The IR sensor on the television would probably need replacement.
Sep 04, 2008 | JVC Televison & Video
Televison & Video Logo
81 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
